wet setting floats
Discussion in 'XJ Technical Chat' started by Kennyhartman, Mar 20, 2014.
  1. Kennyhartman
    Kennyhartman Member
    northwest ohio
    I rebuilt my carbs and am trying to wet set my float levels, I am not able to get fuel into #1 or #4. My question is, do they sometimes airlock? When I took the bowl off it acted like it was under a little pressure but it did not have any fuel in it. It got dark before i could spend a lot of time on it but if you guys have any suggestions please let me know.
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
  3. Kennyhartman
    Kennyhartman Member
    northwest ohio
    I will try letting gas flow to them longer, maybe just did not give it enough time. Will work on it tomorrow.
  4. Polock
    it don't take long to fill up, you have some stuck floats.
    if that's the first time you had gas in them, they might be stuck from being upside down during the rebuild.
    open the drain and give them a smack with a screwdriver handle, they might work themselves loose. by the time your done with the wet set you'll know if you have a problem
  5. schmuckaholic
    California
    Should take five or ten seconds. Concur on the stuck floats.
    Interesting thing to consider trying (although it could get messy) would be to put the carb rack on a stand, hook up a fuel supply, take a bowl off one of the affected carbs and start the fuel flowing. See what happens.
  6. skippy344
    skippy344 Member
    Aggieland, TX
    Here is a tool I made to help with bench setting the floats and checking for float leaks:
  7. Kennyhartman
    Kennyhartman Member
    northwest ohio
    Thanks guys, I made a holder like yours skippy, and had two stuck floats.
  8. skippy344
    skippy344 Member
    Aggieland, TX
    LOL, Kenny! Yep, better to find it here, than filling your oil with gas!!
  9. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    Awwwww.... Isn't that cute! That plastic man is giving your carbies a hug!! :oops:
  10. skippy344
    skippy344 Member
    Aggieland, TX
  11. Rice_Burnarr
    Rice_Burnarr Member
    Haha!! I don't know why, but that's what it looked like to me at quick glance!
    Your "Carb Buddie!"
  12. skippy344
    skippy344 Member
    Aggieland, TX
    I get no respect! LMAO!!
  13. RickCoMatic
    Did you pull the Float Valve Seats?
    There are "Beenie-screens" to be cleaned on them.
  14. Kennyhartman
    Kennyhartman Member
    northwest ohio
    The float seats are new, and yes i did pull them to check them. After the initial problem getting gas they did not mess up after that.
  15. Kennyhartman
    Kennyhartman Member
    northwest ohio
    Thank you guys for the help. Installed carbs and battery and started immediately. Now to sync and colortune...
  16. skippy344
    skippy344 Member
    Aggieland, TX
    Good Job, Kenny!
    Just finished with Rosie's carb rebuild, float measure, wet set, sync and air mix adjustment.
    Rosie is running fine!! She always amazes me how much fun she is to ride!
    And I have an '06 FJR, and that machine is a total blast!!
    I am still impressed, with this 32 year-old XJ!
