curse you carb one...
Discussion in 'Hangout Lounge' started by som1somwhere, Mar 30, 2014.
  1. som1somwhere
    som1somwhere Member
    United States, Illinois
    wet set my carbs today and all looked fine with carb 1 on the stand then went through the pain of installing and carb 1 cursed me and started overflowing while on prime... grrr :evil:
  2. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    Sometimes the float valve will need to "seat" to function properly. Sometimes a gentle "rap" on the fuel bowl with a screwdriver handle will do to help.
    Before removing the carbs again, you may want to remove just the bowl and manually move the floats up and down a few times if the "rap" method didn't work.
    hope this helps
  3. som1somwhere
    som1somwhere Member
    noo she wasnt adjusted quite right. it was bugging me so i did it last night. alls fine workin now. my choke never worked right i thought it was just the way it was but now it works because of the levels.
