Cleaning and Rebuilding Carboretors Today
Discussion in 'XJ Technical Chat' started by nammy, Jun 14, 2007.
  1. nammy
    nammy Member
    Upstate New York
    I needed to be done.
    Check out the pics.
  2. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    Wow! Those float bowls look nasty! Good scrubbing!
  3. nammy
    nammy Member
    Upstate New York
    Yes! dirty dirty carbs
    I should see a difference in preformance when done. B)
  4. Robert
    I'll say! Look like sound units just the same. Should clean up all right.
  5. Kenbo
    Kenbo Member
    Central Scotland
    Thanks for the picts
    That is something I need to do in the near future, but did not know what they looked like inside for real. Line diagrams are onething but to actualy see it is another.
  6. nammy
    nammy Member
    Upstate New York
    I was wondering if anyone ever tried this for cleaning their carbs.
    Use some of that carb cleaning liquid in it.
    Ultrasonic Cleaner
  7. nammy
    nammy Member
    Upstate New York
    Before After
  8. Alive
    Alive Active Member
    Queensland, Australia
    Wow they cleaned up good....
    Just remember when you put the rack back together (join them) to square them up from the intake side :)
  9. nammy
    nammy Member
    Upstate New York
    Copy that, thanks
  10. Piersol
    Piersol Member
    Red Lake Falls, MN U.S.A.
    WOW!!!
    Did you use the ultrasonic cleaner? I have often thought about one of those also for cleaning parts. I may still pick one up.
  11. nammy
    nammy Member
    Upstate New York
    No, I didn't get one, but I'm still thinking about it. I need to physically see the size.
  12. nammy
    nammy Member
    Upstate New York
    I got"R" Done!!
    Works great, when for a 60 mile ride. What a great feeling to have it done a running superb.
  13. On1wheel01
    On1wheel01 Member
    Nc
    Hey what did you use to clean the carbs? A wire brush and can cleaner. or the big bucket cleaner? They look like new, mine has some bog when i pull it up sometimes, wondering if that would help.
  14. nammy
    nammy Member
    Upstate New York
    I use the Gallon can Chem-Dip for Carbs and auto parts cleaner.
    It works really great. I didn't use and brush. All I did was dip and rinse in warn soapy water and sprayed Carbs cleaner everywhere and used compress air to make sure everything was dry and cleaned out.
