gAs leAk... common?
Discussion in 'XJ Technical Chat' started by theyucky, May 1, 2014.
  1. theyucky
    theyucky New Member
    San Diego, CA
    1981 maxim xj550
    Neighbor told me he thinks the petcock needs to be replaced.. Gas leak.
    Well, I put some gas in it and started it up last night and it is dripping fuel a lot worse than I thought, and it doesnt appear to be coming from the petcock fuel switch.
    Trying my best to see, it appeared to be coming from the part of the motor that is right below the seat.
    I am realizing this might now be enough information for a diagnosis, but if you have any suggestions/ideas I would love to hear them. Thanks!
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Stop running your motor. It sounds like you have gas coming out of your airbox. You problay have a crankcase filled with gas. Your petcock and or carbs need some attention.
  3. theyucky
    theyucky New Member
    San Diego, CA
    Ya once I got it started I only ran it for about a min but then noticed the drippin gas a look worse than I thought so I shut it off. It kept dripping down after it was off. Going to try to take a better look next time I can take a day off.
    Thanks dude.
  4. hogfiddles
    Get a rebuild kit and rebuild it......
    Dave
  5. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1 on the advice given. everything is 30yrs old. the petcock is not shutting off and is leaking into the carb bowls which has a stuck open float valve(s). imo also rebuild the gas cap. hope this helps.
  6. bigfitz52
  7. theyucky
    theyucky New Member
    San Diego, CA
    Wow thanks everyone. I will take a better look with a friend who knows more about motors than I do and will report back.
    Hopefully everyone is having a great weekend!
  8. otroz
    otroz New Member
    O\'Halloran Hill, South Australia.
    Hi - Im also having probs with petcock still leaking after all rubbers and that rear diaphragm were replaced - maybe I need to stretch spring as well?? It seems to be leaking gas from rear of petcock still. Ideas? Can we purchase anywhere ....WEMOTO??? the complete petcock unit afresh?? Thanks all.
