diedo block what dose it do
Discussion in 'XJ Technical Chat' started by dean.james, May 1, 2014.
  1. dean.james
    dean.james New Member
    west yorkshier
    I have an xj550 and it is done and finshed after 6 months but now i have it done it dose not want to work as i put it all back as i got it out and when i went to start it smoke came from tje head light area so switched it off and opend light then put it back on and it was fron the diedo block can i fully remove it and if so what will not work or where can i get a new one from in the uk.
  2. bigfitz52
    No, you can't just remove it.
    It contains diodes that are part of various, different circuits on the bike. Yamaha conveniently located them in the same "block" even though they belong to different circuits.
    WHAT circuits they each belong to will vary from model to model; your Euro-spec XJ550 will be different from the 550 Seca sold here as well as different from the 550 Maxim.
    You need a circuit diagram specific to your bike to figure out what each of the diodes are for.
  3. dean.james
    west yorkshier
    Can i just buy a new one its a xj550 maxim on a 1982
    If so do you or any one know where in the uk i could got one
    I have looked on ebay and there is one but it's for usa amd postage is 30 pound
  4. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    you need to find the cause of the failure, putting a new one on a faulty circuit will just result in wanting another new one .
    I thought the diode block was under the tank?
    circuit diagrams are here
    http://xjdiagrams.thundervalleypower.com/
    stu
  5. dean.james
    west yorkshier
    I can find lots for yamaha but not for xj550 will they all fit as they all look the same and have the right wires in the same place.
  6. fatnfast
    fatnfast Member
    South East England
    The diode block for the xj550 4v8 is also used on the following other Yamaha models:
    TDR250 (88-90) , XJ650 4K0 (80-) , XJ900 31A/1FW , XV12/XVZ12 (83-)
    Yamaha part number :4L6-81980-M0
    I think they are still available new in the UK, but you may be able to pick one up cheap by trawling ebay
    Hope that helps :)
  7. bigfitz52
    The 550 Maxim is a "5K5" and the pn for the diode block is 4U8-81980-M0-00, the same as for the USA-market 550 Seca (4U8.)
    Another member and I had compared a 4V8 (Euro-spec 550 "Seca") and a 4U8 (USA-Market 550 Seca) diode block a couple months back and discovered that the number of wires and their placement in the connector were different between the two.
    The 4L6 part number is likely not going to interchange. The 550 Maxim should use the same part number as all the USA-market 550s.
  8. fatnfast
    fatnfast Member
    South East England
    Sorry, yes, my part number is for the 4v8 only. Mind you, there seem to be more maxims now in the UK than original UK Spec bikes, so you stand a good chance of getting a used one. :)
    They are still available new for about £25 from Yamaha
    Linky: http://www.cmsnl.com/products/diode-ass ... u881980m0/
  9. bigfitz52
    This might help. This is a pic that clearly shows the diode block in a USA-market 550R, which is pn 4U8-81980-M0-00. Ignore all the circles and letters, they're from a different article. The diode block is directly below the lower red circle.
    If that looks like your diode block, then that's the part number. If not, then we need to have somebody give us a look at a Euro-spec part, the 4L6 part number.
    HOWEVER: The diode block itself is not the problem; yes you may have killed it, but it didn't smoke because IT is "bad" something else is wrong.
    The diodes in there are part of the sidestand/clutch switch/safety circuit and the headlight relay "latching circuit." You probably have a dead short somewhere; not good since the headlight latching circuit is tied directly into the alternator/regulator circuit.
    You need both a wiring diagram and a circuit diagram; PM me with an email address and I can send those to you.
  10. dean.james
    west yorkshier
    I will look round for new / used block and go over the loom once more then if it bose not work i will have to try and make a new loom if it is posable to do so or i am stuck with a bike that dose not work
    You can see the loom in mods forum under
    My xj550 first build
    I have just had the diode block off and taken tape off it and this looks like the short and only part that is f… just look at this what some one has done to it no wonder it dose not work and has smoked once power is on i was looking online and the shape was all wrong now i know why ………
    [​IMG][/url][/img][​IMG][/url][/img]
    This could have cost me if i just got on and went for ride i have found one for 27 pounds new
    Thank you for your help so far you all rock
  11. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  12. Polock
    Those components could be replaced for 2 or3 dollars
  13. hogfiddles
    Now we can finally see inside of one! Time for someone to do a write-up!
    Lol
    Dave
  14. dean.james
    west yorkshier
    Yes and if they do i may try and fix it better than the last person did ha ha ha
    Ok that note there is no side stand switch on side stand relay they have been looped out could this have shorted the diode block just want to know before i put on the new one
