Painting a tank for the first time
Discussion in 'XJ Modifications' started by sawyermr5, May 8, 2014.
  1. sawyermr5
    sawyermr5 New Member
    Nashville
    Ok, so I've never painted a tank before, but I want to take a shot at it. I'd like to paint my '82 xj550 tank.
    The Yamaha logos have been removed, so there's the dents on the tank from where they were mounted. I've sanded them down as much as possible, but they're still noticeable. I think I saw one time on here that someone used a putty or foam of some sort to spray on it then sand down? Not sure.
    Also, I'd like to know exactly what I need to buy as far as primer, what type of paint, etc. Basically an entire step-by-step. I plan on rattle-canning it.
    I'd like to get a grey color like this, and I want to do a black stripe (3-4") down the middle of it, and put the Yamaha fork logos on each side of the tank.
    Any other advice would be awesome as well.
  2. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    all you need to do is buy a can of bondo
    fill the emblem hole.. sand it all nice and smooth
    then prime.. and do your painting
    I used Rustoleum at 4 bux a can
    and that is fine
    the problem is you need to clear coat the tank when done
    or any drop of gas will ruin all the hard work
    you will need at least a can of this
    http://www.ebay.com/itm/Eastwood-2K-Aer ... ls&vxp=mtr
    I needed 2..
    and then when dry.. you wet sand and then polish
    if by chance you get no runs, and like the orange peel look
    you can leave it
    I got a few runs
    and after 2 cans I decided that a few blemishes were gonna
    have to remain
    but it still turned out great
    http://xjbikes.com/Forums/viewtopic/t=46128.html
  3. sawyermr5
    Nashville
    Rustoleum Primer and Paint? How many coats?
    I'll pick up a few cans of clear coat as well when I buy the paint. Thanks.
    Good looking bike btw, I plan on wrapping my exhaust as well.
  4. Hotcakesman
    South Dakota
    I used one can of primer.. 2 coats
    then about 3 coats of paint
    I think I ended up getting 2 cans
    the bondo is easy... apply and then sand... coarser grit
    to finer grit
    wrapping the exhaust is tricky.. but make sure to
    buy the silicone spray.. the last thing you want is for it to
    come off driving down the road
    ohh and when you put your exhaust back on
    do it piece by piece.. lesson learned
  5. sawyermr5
    Nashville
    Thanks, I'll post pictures as I do it. I'll probably get started as soon as my seat gets back from the upholstery shop.
    As far as the exhuast goes- how far back did you wrap them? I was thinking about trying to go all the way to where the tips start. Or would you just recommend wrapping the 4 pipes and stopping where they join up?
  6. Hotcakesman
    South Dakota
    I just did the front parts.. I sanded and painted the back with
    high heat enamel
    really was not hard to do
    the wrapping is not hard
    just a pain when you have arthritis in your hands like I do
    I used wire and hose clamps
    wire 1st to secure it.. then I used hose clamps just in case
    the sanding is not to hard to do.. maybe took me half an hour
  7. sawyermr5
    Nashville
    Maybe I'll just do that then, yours look really good. I've got a guy that's gonna paint my engine with high heat enamel, so maybe I'll just get him to do the exhaust as well so they match. Did you paint the whole thing and then just wrap over it, or take off the front parts, wrap them, then sand and paint the remaining?
  8. Hotcakesman
    South Dakota
    why paint what you are going to wrap?
  9. Orange-n-Black
    Memphis Area
    Engine paint will not last on the exhaust, you need exhaust/header paint. I would do the paint on the pipes and forget the wrap.
    Make sure you sand the tank area for bondo down to the metal. I used dupli-color clear engine enamel over the painted tank on mine, not expensive and holds up well.
  10. sawyermr5
    Nashville
    Any reason in particular you say forget the wrap? I think it looks pretty slick
  11. Orange-n-Black
    Memphis Area
    1. Wrapping pipes is a PITA.
    2. Wrapped pipes are slower to dissipate heat.
    3. The wrapping can come loose and lead to more maintenance.
    4. Don't know if its true, have heard the wrap holds moisture and will rust pipes quicker.
    Some may argue these points. Wrap may look good, but painting the pipes is cheaper, quicker and less hassle. The paint also comes in a few different colors.
  12. Hotcakesman
    South Dakota
    Wrapped pipes do look sick
    but like they say.. it is a pain.. I think it took me
    about 2 hours to wrap all four pipes
    the hard part is getting the mounting plates in the right
    spot.. you must get them in place then wrap.. a bit tricky
    but you need to just think about it
    then there is the fact that you are using insulation
    so you have to make sure to not touch them too much
    aka wear rubber hospital gloves or EMT gloves
    and of course you are dealing with wet wrap.. since you have to
    soak it
    once in place you have to make sure they are not going to
    move.. I sprayed them with the silicone
    now they are solid and look great
    but I could have high heat enameled them just as easy
    overall I love the look.. had the wrap not been given to me
    I think I could have spent 50 bux elsewhere on parts
  13. sawyermr5
    Nashville
    I've got an extra exhaust, so I might just paint it and see how I like it.
    I'd really like a 4-1 exhaust, both are 4-2.
  14. bigfitz52
    Some even argue that point.
    And I've never seen wrapped pipes on a RIDDEN bike that didn't permanently look like crap after a couple thousand miles. You can't subsequently clean the wrap effectively.
    If they can't be chrome, then Jet-Hot coating is the way to go. If that's too expensive, then properly applied, a DIY header paint can hold up quite well.
  15. thejewishguy
    thejewishguy Member
    Miami
    Wrap it but wear a long sleeve shirt or you will be itching later..
    if you don't want to wear a LS sleeve shirt then my suggestion is to spread vaseline petroleum jelly on your arms so the fiberglass dont stick to your body... I used to hang gil liner for cargo planes and that is what i used to keep from itching.. also use gloves and a paper mask.
  16. thejewishguy
    thejewishguy Member
    Miami
    When you go paint your tank use build primer or etching primer...
    then wet sand it and then use a precleaner to remove grease from your fingers and then a tac cloth (home depot)
    Paint use two stage
    Base paint and then clear coat.. ...
    Dont use single stage... it runs and then it looks like a mess...
    take your time dont rush it.
  17. sawyermr5
    Nashville
    Ok, if I'm gonna paint it... what's the best way to do it in a flat black? Is that possible or am I out of my league here?
    I'm picking my second set of exhaust from @Thrasher on either Tuesday or Wednesday. They're 'chrome' now, but they're obviously used and have a few very minor flaws. They're 99% rust free from what I can see in the pictures as well.
  18. thejewishguy
    thejewishguy Member
    Miami
    Flat Black is overdone !
    Too many people have done that.. Since im using chrome in my build i opted to paint my tank and fenders glossy black or a polished satin finish.
    Check my build link below
  19. Orange-n-Black
    Memphis Area
    How about flat/satin dark blue with a gun metal grey frame?
  20. sawyermr5
    Nashville
    I don't think I'm ready to tackle the frame yet haha. The tank is currently a flat gray (got bored with a buddy and plasti-dipped it), but I'm probably going to paint it a glossy gray. I'm open to any color scheme ideas as far as the exhaust/tank though. The frame will probably stay black for now though.
    Here's what the tank looks like now (I've added a U to the back of the frame and made a new seat pan-currently being upholstered. I've also gotten new tires) but you can see what I'm working with.
