Where to get a Spin on Oil Filter Adaptor Plate
Discussion in 'XJ Modifications' started by Alive, Oct 27, 2009.
  1. Alive
    Alive Active Member
    Queensland, Australia
    Want one for your XJ??? See if you can find a 1994 (or there abouts) XJR
    Check out these....
    Photo 1 shows 3 oil coolers... Left is an XJ650, middle a 94 XJR400 and an XJ900 on the right...
    So I bought this 94 XJR400 for $100NZD in not so nice condition
    and low and behold it's has a spin on oil filter that will fit on my XJ900... Nice
  2. mlew
    Re: Spin on Oil Filter
    Good idea, that will probably adapy to most XJs. I hope your next project will be to replace the bent forks so you can ride.
  3. Alive
    Alive Active Member
    No chance.... XJR is back up for sale... I have a $350NZD bid on it already :)
  4. Kickaha
    New Zealand
    Can you measure the swingarm for me?, width across the front from inside of frame to inside of frame where it pivots and length from swingarm pivot to centre of rear axle?
    Thinking of a swingarm out of one of these for my 550 project
  5. rockerto
    rockerto Member
    Toowoomba, Queensland
    :lol: :lol: :lol: Got parts and a profit, nice
    That XJR oil cooler will be good up here, thanks for the tip Alive.
  6. Ltdave
    Ltdave Member
    not going to happen in the states. no such animal ever made it to our shores (unfortunately)...
  7. Alive
    Alive Active Member
    Can do.... Will PM you the details tonight... Guy who has the lead bid is buying it for parts
  8. skylrk62
    skylrk62 Active Member
    Illinois
    I'm having an issue with the union bolt assembly. The bolt I puchased is not the same in the pictures above. the one I got 90401-20145-00, is much shorter and does not pass the oil cooler plate. Can someone help me out on this? It will look sweet and be a performance and practicality upgrade. I'm almost there! But I need some insight on this!
  9. Alive
    Alive Active Member
    Sounds to me like you need a standard adaptor plate bolt off any xj with an oil cooler
  10. skylrk62
    Illinois
  11. RickCoMatic
    If you use a YAMAHA Oil Cooler Adaptor, ... you NEED the Union Bolt to affix the COOLER Plate the Engine:
    90401-20089-00 BOLT, UNION
    Then, you NEED Yamaha Oil Lines which Mount to the Adapter.
    Phillips~Lockhart used too market a Universal Kit.
  12. Alive
    Alive Active Member
    Hows the ankle Rick?... Hope your back on the bike soon :)
  13. skylrk62
    Illinois
    Thanks Friend! Now I just have to find one, it's discontinued.
  14. chacal
    We carry the cooler union bolts (and the special washer used with it), as well as complete spin-on filter kits that can be used with or without the factory oil coolers. Drop me a PM or e-mail and I'll get you all the info you need.
  15. mharn091480
    mharn091480 New Member
    makati philippines
    Hello guys im mharn from philippines i need some help on my xj400 , i already replace the O-ring in the oil filter adaptor plate but still leaking i remove it again add some silicone gasket but still no luck still leaking . It only happen when the engine is running.
  16. mharn091480
    makati philippines
  17. ozzydaveo
    ozzydaveo New Member
    Oz
    Also check the O ring under the centre securing bolt - it is often not included with cheaper Oil filter kits
  18. k-moe
    That has nothing to do with the spin-on filter adapter plate. The oil filter bolt and cover get bagged and stored on a shelf once the adapter plate is installed.
  19. XJ550H
    lines should come off to check instalation.
    new oring for housing if you can get correct size.
    if there is a gap maybe check flatness of mating surfaces,
    I do not have a cooler on most of my xjs but I use a thin coat of rtv on the filter housing to seal it. it is very fussy on its position on the motor .
    sometimes it leaked when changed filter sometimes it doesent so i rtv the outter edge . the orings that come with filter are not correct size
  20. Franz
    Franz Well-Known Member
    Scotland UK.
    Can the 900f be converted to fuel injection?
  21. Franz
    Scotland UK.
    Do you have any more information on this thanks? It will need a different electronic unit for injection timing and opening duration I expect, and parts such as throttle bodies, MAP sensors, throttle potentiometers.
