Time for Apes!
Discussion in 'XJ Modifications' started by 82NewToMe, Jun 10, 2014.
  1. 82NewToMe
    82NewToMe Member
    Harrisonburg, VA USA
    Do any of you guys know where to source varying length throttle and clutch cables for swapping to taller handlebars? Need for my XJ.
  2. k-moe
    Any bicycle shop (a real shop; not Walmart) can make cables to length for you.
  3. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Fluid filled brake lines? Probably not.
  4. 82NewToMe
    82NewToMe Member
    I got a guy that makes my brake lines, the biggy is the throttle/clutch cables.
  5. k-moe
    The OP didn't ask about those :wink:
  6. Polock
  7. strat
    strat Member
    Williamsport, PA
    i've had good luck with motion pro.
