Anyone seen/tried these aftermarket coils before?
Discussion in 'XJ Modifications' started by kudoskun, Jun 18, 2014.
  1. kudoskun
    kudoskun Member
    Minneapolis MN
    http://accel-motorcycle.com/motorcylce- ... ctive.html
    They make them in different resistances, but serving as an example product -- it would seem like a full aftermarket replacement -- working with the CDI on our bikes.
    Thought it was worth a mention and discussion.
  2. schmuckaholic
    California
    ...except we don't use CDI. We have TCI (Transistor Controlled Ignition).
    I did a quick forum search on "accel coil", which returned plenty of hits. I don't know if anyone on here has actually installed a set, but if not, perhaps you could be the first and let us know how it works out. :D
  3. kudoskun
    kudoskun Member
    Minneapolis MN
    My mistake, I keep mixing the two acronyms. Oh well...
  4. Polock
    they would work IF they fit, the posts on the side like that might not
  5. schmuckaholic
    California
    (shrug) Happens a lot around here. No worries. :)
    It does say "point or electronically triggered", but it also repeatedly mentions CDI.
    Hadn't noticed that before. I imagine someone could (or has) hack(ed) together some mounting brackets for yon beastie, as has been done with the Dyna coils.
    Next question would be size; are they as large as the Dynas? If so, then the flasher unit would need to be relocated.
