Snorkel removal?
Discussion in 'XJ Modifications' started by wrenchmonkey, Jul 3, 2014.
  1. wrenchmonkey
    wrenchmonkey Member
    Vancouver Island
    Has anybody tried removing the rubber intake snorkel that feeds air into the air filter box on an xj750? Just curious how it worked out?
  2. k-moe
    Mine came without the snorkel when I bought it. It does serve a purpose. The snorkel helps smooth out the intake and also helps to keep the airbox filled during the pulsing that occurs when the intake valves close. When I aquired a snorkel and put it in there was a noticeable improvement in smoothness and responsiveness while accelerating. Properly engineered airboxes are perhaps the single most important part of ensuring that an engine can produce the power that it was designed to. Leave the snorkel in.
  3. wrenchmonkey
    wrenchmonkey Member
    Vancouver Island
    Nice. That's what I figured. CV carbs like even air flow from what I gather, so that makes perfect sense.
  4. engraverwilliam
    engraverwilliam Member
    Baldwin Hills, South Los Angeles
    can someone send me a link or post a pic of said snorckle? I want to see if My bike has it. Thanks.
  5. k-moe
    If the opening to the airbox (under the seat) has a soft, rubber lip then your snorkel is in place. It protrudes into the air box.
  6. wrenchmonkey
    wrenchmonkey Member
    Vancouver Island
    So if I add another snorkel that should be twice as good right? HAHA!
  7. k-moe
    Add three and you can out-drag a late model Civic with a fart can on it (barely). :lol:
  8. wrenchmonkey
    wrenchmonkey Member
    Vancouver Island
    I should add some rim stripes and go fast stickers too. I wonder how much faster a huge rear wing will make my bike go? I can't stop laughing from the visual I'm getting. :p
  9. RickCoMatic
    I think the Snorkel limits MAF (Mass Air Flow).
    Regulates in a way.
    The is a finite amount of air allowed in.
    But I have seen both innovated and screwball Airbox jobs.
    One kid used a chunk of Drum Corps bugle.
    Removed and screened.
    Removed; Not screened.
    There was one that looked like a Fighter Plane strafed it.
  10. peganit2
    peganit2 Member
    Davison Mi
    All carbs on a multi cylinder 4 stroke engine with a throttle plate per cylinder and no cross over manifolding is harder to tune than otherwise.
    The intake valve is only open for 1 of the 4 strokes when the throttle plate is open, and if the air intake has no where else to go, it just reverberates in and out of the that single intake track when it slams into the back of the closed intake valve.
    The snorkel and intake box can be thought of as the cross over manifolding.
    P.S. The carbs also have to be larger, because each cylinder is getting only the breathing capacity of the single throttle bore, instead of sharing the intake air with the other throttle bores.
  11. Polock
    i've had mine in and out a few times, doesn't seem to make any performance difference. what it does do when it's out is make a lot of noise when you go wot
  12. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Pic of snorkel for those who are curious
  13. Polock
    is that in all the way?
  14. peganit2
    peganit2 Member
    Davison Mi
    That's what she said.
  15. wrenchmonkey
    wrenchmonkey Member
    Vancouver Island
    LOL, I was waiting for somebody to say that!
  16. Polock
    Well like that the thingy would be up against the seat and would bring no happiness
    To the rider.
    Your turn,
  17. peganit2
    peganit2 Member
    Davison Mi
    I think that would depend on the rider.... 8O
  18. Polock
    i'll quit before we get in trouble
  19. peganit2
    peganit2 Member
    Davison Mi
    Smart man.
  20. wrenchmonkey
    wrenchmonkey Member
    Vancouver Island
    what were we talking about again? lol
