New here and could use some help!!
Discussion in 'XJ Technical Chat' started by maxim-man, Jul 29, 2014.
  1. maxim-man
    maxim-man Member
    ontario canada
    Hey everyone, new to the forum and also new to the motorcycle world! I just picked up a 1984 yamaha xj650! I just love the look of the old school bikes!
    I'm hoping to gain lots of knowledge here and I would like to start off with this: bike wasn't running when I got it but owner said it ran when he stored it 2 years ago. First thing I did was pull the carbs and gave it a thorough bath, I then set the floats/fuel level to spec. Petcock is functioning fine and compression is 150, 145, 150, 153 (which I was happy to see) with all this it still won't run, funny thing is after it sits for a few hours it will actually turn over and chug a bit but wont stay running and won't turn over again till later! I've not yet changed the plugs but there is spark and plugs are bone dry after all the attempts starting! I'm a little stumped at this point and not sure what to look at next! Any help would be greatly appreciated! !
  2. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Welcome to the forum, you will find all the information and help you may need in the forum.
    The first thing you may want to do especially with a bike that clearly has not been maintained properly is to check the valve shim clearances. Once that is done you can move on to setting up the carbs properly.
    When you say a bath to the carbs what do you mean? Did you replace any parts? There are a lot of passages that must be spotless to ensure proper operation including the enrichment well on one side of each carb bowl.
    Best wishes,
  3. drifter
    drifter Member
    Kingston Ontario Canada
    I had to disassemble and clean these carbs thoroughly.. There are some passages in the float bowls that are very important to clean .. They are part of the choke/enrichment system.. Also would be wise to take the entire enrichment system apart and clean it.. There is a write up that is very thorough on this site.. ATM I only have my phone so hopefully someone else can find the link for ya.. Welcome to the site... :)
    Oh yeah .. Almost forgot.....
    Valves valves valves.... Get a feeler set .. Take the tank off..and the valve cover .. Check the clearances ... Very important.. Also there is a write up somewhere on this site..for that too
    Where in ont are you ?
  4. maxim-man
    maxim-man Member
    ontario canada
    I didn't replace any parts cuz tbh it didn't really look bad inside there but I took every single piece out and cleaned thoroughly using carb cleaner and compressed air! Also triple checked every pin hole to make sure it was free!
    Thx
  5. maxim-man
    maxim-man Member
    ontario canada
    I've not checked valve clearance but I guess I should check this! My gut is telling me that it may be some sort of electrical issue!
    I'm in whitby which is on east side of Toronto! You?
  6. drifter
    drifter Member
    Kingston
  7. maxim-man
    maxim-man Member
    ontario canada
    Cool, not too far! Where do you get your parts from?
  8. ecologito
    NASCAR Country, NC
    Make sure you have a fully charged battery. Having the bike idling won't charge the battery.
    Do you have the original fuse box? they tend to be a weak point on the electrical system as the terminals deteriorate with time even if they "look ok".
    The same goes for the carb parts that wear out. The float valves may seem ok but the rubbing and moving up and down will wear them out ever so slightly that you may not see it but they sure will.
    Best wishes.
  9. maxim-man
    maxim-man Member
    ontario canada
    Ya I'm constantly charging battery as multiple attempts at starting drain it pretty quick! I'm currently inspecting all the wires to see if there's anything visible going on! So far I don't see anything obvious! Here's a question, I've not changed the plugs yet but haven't thought it quite necessary yet as after all the attempts at starting they are still bone dry! If it was a spark plug issue they would be wet would they not? I'm also trying to find out if there's anything electrical that could cause this! If I let it sit for a few hours it will turn over and chug once or twice and that's it till I let it sit for awhile again!
  10. drifter
    drifter Member
    How clean are the plugs ? What do they look like.. Black sooty ? Etc
  11. maxim-man
    maxim-man Member
    ontario canada
    They were a little black, came that way when I got them! I am gonna replace them just to rule that out! Just trying to limit the amount of $$ I spend till I know I can get her running! I haven't replaced yet cuz I figure that if it was that they would be wet. I'm thinking I'm just gonna change anyways!
  12. drifter
    drifter Member
    Take a small wire brush to them clean em up.. Check the electrode... Some wire brush shed so make sure there are no wires on the plugs.. .. Also if you have a spark gap tool check the gap make sure its in spec...0.7-0.8 mm or 0.023-0.032 inch. If I remember right
  13. maxim-man
    maxim-man Member
    ontario canada
    I did this exactly! Is there anything electrical that could cause this?
    Also, in the birds nest of wires in the headlight I found a couple wires that lead to nothing but don't see anywhere for them to plug to so not sure what they are for! I have a manual but with electrical it might as well be written in Chinese to me! Lol here's a pic
  14. drifter
    drifter Member
    Electrical... I don't have any ideas ... I haven't looked in my head lamp... I doubt there is something in that location related to ignition.... Will she fire with quick start fluid.. If you don't have a bottle of staring fluid head down to crappy tire or princess auto and get some..
    I found it helped me when I couldn't get mine to fire.. If it fires on starter fluid... Chances are its carb related... There are way smarter folks on here that might point you in right direction
    Also check for spark pull spark plug re onect the ignition wire.. Hold it against the engine and turn it over... Bes to do this indoors or at dusk .. The spark is hard to see if the light is too bright
    Spark mixture compression.... All three needed to run
    Also I would change you thread title to something that says your have no start issue.. It might get some attention from the gurus on this site... Ie help bike won't start can't figure it out... Or some such... If you where closer I would come by and look... Maybe after I get back from vacation.. whitby isnt that far...Leave on sat night
  15. ecologito
    NASCAR Country, NC
    If the bike is not starting and they are bone dry then no gas is being delivered, that sounds like carbs are not fully clean. Just like anything in life, if you kinda do it, it kinda work. Once you thoroughly clean them and replace all the parts that wear out then your carbs will work like new.
  16. maxim-man
    maxim-man Member
    ontario canada
  17. bigfitz52
    You need new spark plugs; put the petcock on PRI (assuming fresh gas) and unless you need a new battery it should fire up.
    If the battery is soggy, it will spin all day and never fire. If there's no gas in the carbs, it's possible there's an issue with the vacuum operated petcock; that's what "PRI" is for. However, if your floats aren't right, you could end up filling your motor with gas so be careful with "PRI" it's like turning on the faucet.
    Shortcuts will only lead to heartache. Follow the above advice.
  18. maxim-man
    maxim-man Member
    ontario canada
    I took every piece apart and cleaned very thoroughly! Used compressed air and did it a couple times just to be sure! And tbh there wasn't a spot of anything in these carbs, I was quite surprised! I've got them off again and going through process again to be sure!
    Thx for input!
  19. bigfitz52
  20. maxim-man
    maxim-man Member
    ontario canada
    Im gonna pick up new plugs so I can rule that out! At first I was unable to get fuel in the bowls and when I went back in to check the floats I noticed that someone had been in there and floats were way off and upside down to boot! So I fixed them and set them according to spec and checked fuel levels and everything was where it needed to be! So I now have confirmed fuel in the bowls but I'm assuming now that the fuel is not coming out of them! I did put petcock on prime for about 20-30 seconds and switched to on and nothing! I have confirmed spark but not convinced fuel is getting to plugs as they are bone dry! I've also confirmed that the petcock is functioning as it's supposed to be! I've got the carbs off again and am gonna check them out again, not sure what else to do at this point!
    Thx for the input!
  21. maxim-man
    maxim-man Member
    ontario canada
    This is the exact write up that I followed! Made the stand and all! Lol
  22. hogfiddles
    Did you make sure that the well in the bowl is open? there is a very tiny jet in the bottom of the well. The larger hole at the bottom allows gas to fill into the well, the jet meters the gas that is picked up by the enricher tube. The tube and the jet need to be clear. I use banjo and dulcimer string ends to clean these out. Once the tube is clean, you can blow or suck air through it.....not a lot, but enough to feel that it's definitely open. You'll know the jet at the bottom of the well is open once you can stick the carb spray tube down the well and it squirts a mean stream out the bottom hole------straight into your eye. Then, put the spray can tube right into the hole at the bottom of the corner of the carb, and the spray will spray a mean stream right out the top........right into your eye. I mean it's a seriously strong stream.....when that is open, it'll spray a good 10 ft or more.
    If those wells are not clear, your enrichment circuit won't be able to pull fuel, and you won't be able to get the bike to start up cold.....
    Dave F
  23. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
  24. maxim-man
    maxim-man Member
    ontario canada
    It's funny you mention this cuz I did spray carb cleaner all over myself when I did this! Lol
    I was pretty thorough in my cleaning process as I know how important it is! Every hole I shot cleaner and air through exited on the other end! I did notice something last night after pulling the carbs yet again! I noticed that the arm that opens and closes the enrichment system was being prevented from opening fully as it was hitting the bottom of a protruding screw on the diaphragm! Was only preventing it by 2 - mm but I'm seriously hoping that this is the issue! Fingers crossed! Gonna re check everything else again seeing as carbs are off!
    Thx for the input!
  25. maxim-man
    maxim-man Member
    ontario canada
    Thanks for the link! I'm confident that I did make sure to clean thoroughly but I'm gonna follow this process for peace of mind!
  26. hogfiddles
    That could do it too!
    Yeah, make sure that the pivot stop is on the enriched shaft the correct way and place, or it can hit a screw. If it does that, the the enriched wont open fat enough and the carbs act like you don't have the circuit open(enough).
    Also, did take the butterflies off? If you did that and/or separated the rack, did you do a bench sync before putting the carbs back on the bike?
  27. maxim-man
    maxim-man Member
    ontario canada
    I hope this is the case brother! I did not mess with the butterflies nor did I separate the carbs! I did clean around them but that's it! And as far as syncing I only used the needle method to check it which was good! I don't have the sync gages and I figure this method should at least get it running and go from there!
    Cheers!
  28. maxim-man
    maxim-man Member
    ontario canada
    Wicked news everyone, my monster is alive and well!! Finally got my bike running today and she seems to be running nicely! When I had the carbs off I decided to take the bowls off and 2 of the 4 holes for the enrichment tube were blocked! They were free so what I think happened is crap came out of the fuel tank and got in there! I've now added a filter for the fuel! Next step is to fix the spring on the clutch as it's not springing back cuz now that she's running I wanna check the gears and then I can move on to working on some fun stuff!!
    Wanna thank everyone for their help!! I'm sure I will have more questions! Lol
    Cheers!!
  29. drifter
    drifter Member
    Grats glad to hear your running :)
  30. maxim-man
    maxim-man Member
    ontario canada
    Thx man!
  31. hogfiddles
    See ?!?!?! We're the repair shop that still allows you to walk right out to where the bikes are being worked on AND we say, "C'Mere......look at this, this is how it goes....Here, do it yourself---you're allowed to!"
    We don't have the safety inspectors tell us, "Sorry, you can't be out there anymore......you can't even peek through the crack in the door, either".
    You're gonna be fine, and you're learning how to fix your bike YOURSELF. Awesome, ain't it??!?!?:)
  32. maxim-man
    maxim-man Member
    ontario canada
    Yup! I love it!!
    Cheers!
