Carb Tolerance issue ?
Discussion in 'XJ Technical Chat' started by oldyam, Aug 17, 2014.
  1. oldyam
    oldyam New Member
    Ireland
    Hi All
    I'm hoping that someone can help with this issue, I have a 1980 XJ 650 4K0 (UK model ) in std trim and unmolested with a complete original exhaust system.
    I have an idle issue ( wanders dependant on throttle shaft position ), caused I suspect by worn throttle shafts / carb bodies the carbs are Hitachi HSC 32's.
    Is this a common issue ?
    How much movement is acceptable ?
    Is it normally the carb body that wears or the throttle shaft or both ?
    Is there a fix for this issue ?
    ie, are new throttle shafts available, is it possible to rebush the carb bodies ?
    I have not yet removed the carbs for dismantling as I see no point in disassembling them if there is no remedy other than to replace the whole set, as the bike is running - just not the way I want it to be.
    TIA
  2. hogfiddles
    Throttle shaft seals are most likely. Very common issue, replacement seals are available. Read the writeups here.
    Dave
  3. hogfiddles
    Dave
  4. oldyam
    oldyam New Member
    Ireland
    Hi Dave
    I intend to replace the seals but, what I need to know is how much wear is acceptable in the throttle shaft / carb body as replacing the seals is only going to hide the issue temporarily if the wear is excessive allowing the throttle shaft to lift under throttle application causing the seal to pull away from the shaft creating an airleak as this is the current problem.
    TIA
    Nigel
  5. chacal
    If anything at all wears in that area, it would be the shaft BORE in the carb body rather than the hardened stainless steel shaft. We've never seen an indication of any meaningful wear in either of those areas (besides the seals, of course!) and due to the rather minimal radial loading on these items, it's doubtful that it would be an issue unless they were "million-mile" carbs......
  6. oldyam
    oldyam New Member
    Ireland
    Thanks Chacal
    The reason I ask is that there is approx 0.005"-0.010" vertical lift on both 1 & 4 carbs at the outer end of the throttle shaft.
    This feels quite a lot and given the size of the seal I was wondering if new seals would accommodate this amount of movement for long ?
    Carbs have around 45,000 miles on them as far as I know.
    I'll get to ordering the seals ASAP
  7. bigfitz52
    New, correct seals, carefully installed, will fix the issue.
  8. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    Well I'm going to be the dissenting voice on a couple of things...
    First, the throttle shafts on the carbs I've messed with are not hardened. They appear to be a magnetic grade of stainless, but they are definitely not hardened.
    Second, I'm of the opinion that .005 to .010 (assuming those are thousandths of an inch) is too much slop in the throttle shafts and I'm curious as to how you measured that.
    I haven't measured the play myself in the cycle carbs, but from other similar applications that would be considered excessive. If you're sure about that number, I'll measure a set I have here and see what I get?
  9. bigfitz52
    You'd be comparing Mikunis with Hitachis.
    While it's always possible the carb bodies are worn to the point where new seals won't resolve the issue, it's highly unlikely.
  10. oldyam
    oldyam New Member
    Ireland
    Hi rice_burnarr
    Yes the measurement is in thousandths of an inch, I am more comfortable with that than tenths / hundredths of a millimetre, showing my age LOL.
    I checked the movement by eye first of all, then having seen what I thought to be excessive movement I got out a dial gauge and mounted it to a fixing bolt on a adjustable arm and rechecked my original opinion by moving the shaft downwards as it appears to be lifted at the end possibly by the action of the throttle adjusting screw.
    All measurements were carried out with the carbs in situ as they are still mounted on the bike.
    Having no previous knowledge of these particular seals in this application is why I posed the question re the movement allowable in the shaft / housing without causing the seal to pull away from the shaft there fore creating an air leak.
    Which is what I am attempting to stop at present, I can see that with the current OLD seals that this is happening and was concerned that even if the NEW seals would seal this distance when new that they wouldn't seal for long and in short space of time I would have a return of the original fault.
    No point in wasting money if I need to replace them with a better set first money is just too tight to be throwing it away.
    TIA
  11. hogfiddles
    Wow.. Z I wish MY eyes are god enough to see " approximately .005-.010"
    I can see 1/64" though, for measuring frets.....
    Dave
  12. oldyam
    oldyam New Member
    Ireland
    Well, having been an engineer for over 40 years I am well used to being able to see and judge small increments.
    Try looking at the thickness of a feeler gauge .... say the one you use to check your valve clearances ....... are you saying that you cant see the clearance between the base of the cam and the shim sat in the bucket ?
    Maybe try putting some light on the subject from behind to help.
    5 - 10 thou is well within the normal range for valve clearance settings on a lot of vehicles and is very easy to feel / see even a few thou of variation !!
    BY the way 1/64" is 15.6 thousandths of an inch !!
  13. Rice_Burnarr
    Rice_Burnarr Member
    OK, I'll take a look at the carbs I have here. I really think that .005 - .010 is excessive.
    In a geometry like this, it's very easy to hold tolerances much tighter than that when new. The people who made these carbs are quite capable of doing much better than that even without really "trying".
    Of course, I have no idea what the 45K miles have done to the tolerances involved. Maybe the holes in the carb bodies have worn oval? And if they're worn to that point, I'm thinking that you might be in the market for a set of carb bodies or maybe someone to bore and bush the original bodies.
    Are you sure you weren't including flex in the rubber carb joints to the engine or somewhere else in the measuring system?
  14. oldyam
    oldyam New Member
    Ireland
    Hi Rice_burnarr
    I am suspecting that the problem is in the wear pattern of the bores for the throttle shafts and I was very careful not to allow any flex in the carb mounting when taking these measurements.
    The scenario you have put forward re boring the holes and rebushing is what I was looking at maybe having to do if the seal is unable to take up that magnitude of movement long term.
    That really is a small seal and a lot of movement at 10 thou and I don't want to go down the road of fitting the seals only to find in a short period of time that the seals are leaking again and having to strip & rebuild the carbs again doing further expensive work and replacing seals again.
    I want to do the job once and be done with it. This is not my first XJ, I had one from new back in 82' and as I remember I was seeing the beginings of this sort of issue on that bike then after only about 15-20,000 miles, just didn't realise what it was back then !!
  15. Rice_Burnarr
    Rice_Burnarr Member
    I'm not sure how much slop the seal could even account for, but something else to think about is that if the end of the shaft is wobbling up and down with 10 thou tolerance, then so is the throttle plate inside... And there's no way I would want that to be happening.
    So I'll take a look at what I have here today. Keep in mind that I've got Mikunis and you're running Hitachis, right?
  16. oldyam
    oldyam New Member
    Ireland
    Yes I have Hitach's but that movement in either system is I feel significant.
  17. Rice_Burnarr
    Rice_Burnarr Member
    Me too. I wouldn't want to see that much movement in any carb shaft. Just wanted to let you know that I unfortunately cannot do a perfect "apples to apples" comparison for you.
  18. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Imo getting the carbs correct is the "hat trick" to making a xj a solid runner once every thing else "running" related is in order. Any air leaks will cause her not to idle correctly. Even if you source another rack the seals will need to be replaced. The seals cost a lot less than a rack. Hope this helps.
    Gary H.
  19. Rice_Burnarr
    Rice_Burnarr Member
    OK, I measured my Mikuni throttle shafts and holes.
    Throttle shaft = .3139 dia
    Bore in carb body = .3150 dia
    So I get just about one thou clearance between the two and with that one thousandth clearance I get about .002 up/down play in the throttle shaft as measured on the little stub that sticks out the side of the carb where the "C" clip goes.
    I also inserted a .3114 rod through the carb body and measured .006 up/down play with that rod. So it seems the geometry make it such that the radial play is about twice the clearance between the two diameters. IMHO, that .3114 rod felt quite sloppy to me and I would immediately flag it as a "problem". And you're saying that you've got more play than that??
    To be honest, I respectfully still suspect a measurement method oversight. How about you move the indicator off to the side a tiny bit and put it against the carb body instead of the shaft and repeat the test. In theory, it should read 0.0 deflection, right? Does it?
    If not, you need to rethink your measurement scheme.
    If so, you need to rethink your carb bodies.
  20. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    With all this said, I would break the rack, replace the throttle shaft seals, & fuel rail o-rings....to see if this resolves your problem......then you will know for sure......then you can think about replacing or reboring.....why not take the easier approach...replace the seals & o-rings....
  21. hogfiddles
    Actually, no I can't see that gap because there has always been a little oil there, held by capillary action. I wouldnt trust ANYONE who would just look at the clearances and say, "yeah, it's still in spec" instead of measuring it. The difference between being in spec and being out of spec is only .001", and I won't trust ANYBODY to just eyeball it. That's why God made metric feeler gauges..... Lol
    I can SEE that thickness.... I just can't see something and say "oooh, that's off by about .005".
    15/1000" is also a WHOLE lot thicker than .005", too.
    Dave
  22. oldyam
    oldyam New Member
    Ireland
    Thanks for the help guys, wont get back to this till weekend, as work just went nuts.
    TIA
  23. oldyam
    oldyam New Member
    Ireland
    Actually, no I can't see that gap because there has always been a little oil there, held by capillary action. I wouldnt trust ANYONE who would just look at the clearances and say, "yeah, it's still in spec" instead of measuring it. The difference between being in spec and being out of spec is only .001", and I won't trust ANYBODY to just eyeball it. That's why God made metric feeler gushes..... Lol
    Dave[/quote]
    This actually comes down to reading comprehension, you really need to go back & " read and understand what I wrote" before you start to make comments.
  24. Rice_Burnarr
    Rice_Burnarr Member
    Good luck this weekend and let us know what you find.
    Let's just hope it was a measurement issue and the movement is actually a non-problem! :)
  25. oldyam
    oldyam New Member
    Ireland
    Hi Guys
    Well I stripped out the carbs over the weekend and rechecked the measurements, I was out but only by 0.002" on the worst one ( No.4 ).
    The rest came in as follows :-
    1. 0.005" overall movement
    2. 0.003" " "
    3. 0.0035" " "
    4. 0.008" " "
    As a result of which I am looking for a set of lower mileage carbs, which I hope will all be better that the ones I have now.
    If not at least I hope to be able to create a good set from those and my originals.
    Thanks for the help so far.
  26. hogfiddles
    This actually comes down to reading comprehension, you really need to go back & " read and understand what I wrote" before you start to make comments.[/quote]
    Ahem..... I DID.
    So, I did read everything,and read the whole forum again just to see what I missed...... Nope, didn't miss anything, still understand it just as I did before, and stand by every post I made. So don't YOU be so quick to comment.
    If you feel the carbs are too far out to use and get new ones, I might be interested in the old rack.
  27. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    When you stripped out your carbs you should be able to check roundness and/ or ovality in the shaft hole. Just checking end play of the shaft 'outside' of the hole will not give a true representation of any wear.
    Think of a seesaw; if you measure away from the fulcrum your measurement is amplified.
    But this should all be obvious to an engineer. . . :p
  28. Rice_Burnarr
    Rice_Burnarr Member
    I don't know if the geometry and tolerances of the Hitachis are the same as the Mikunis, but I wouldn't be worried too much about the inner two. The outer two are a little sloppy though. If it were me, I would O-ring the throttle shafts and call it a day. :)
    Here's what I did the last time I was messing with sloppy throttle shafts:
  29. hogfiddles
    Rice!!!! That's awesome..... You just might have cornered a new market !
    That looks awesome
    Davefox
  30. Rice_Burnarr
    Rice_Burnarr Member
    Haha! Thanks!!
    Doesn't pay the bills, but keeps me busy so I don't have time to spend money. In the end, I think it's about a wash. That carb are now worth about $67,000 USD counting my labor.
    That would be about $200 to anyone else.... :lol:
  31. chacal
    Way too kewl for old skool...........
