carbs
Discussion in 'Hangout Lounge' started by raytony30, Aug 26, 2014.
  1. raytony30
    raytony30 New Member
    Sherman, tx
    I havea 1982 maxim 750. I have cleaned the carbs, put them back together, now the bike starts up but has a lot of white smoke. I know I still have to finish setting the idle, but could someone tell me what the rpms should be when idling. And will this help clear up the smoking?
  2. quebecois59
    Idling should be around 1050 to 1100 RPM.
  3. quebecois59
    Almost every time I've seen white smoke coming out of mufflers, it was condensation in the lower part of the mufflers evaporating when the exhausts gases heat it. If it is the case, it will clear out completely when the engine is warmed up.
  4. raytony30
    Sherman, tx
    Thanks, your right, the smoke cleared up after running a while. Thanks for the info on the idle rpms.
