82 xj 750 seca bobber in need
Discussion in 'XJ Modifications' started by REDNECK XXX DISCIPLE, Oct 3, 2014.
  1. REDNECK XXX DISCIPLE
    REDNECK XXX DISCIPLE New Member
    huntington beach
    Whats up y'all I got a 82 xj750 seca in a 750 maxim bobber frame its got straight pipes an cone air pods my current jet sizes are 120 main an 40 port Im gonna go to a 130 main but the biggest port I can find is a 41. Im lookin to go up 2 or 3 sizes anyone got any ideas on what I should do?
  2. TIMEtoRIDE
    The Site Vendor Chacal has jets, but I've never heard of anyone WANTING a 43 Pilot Jet.
    The Mains should be more like 126's
    Are your floats set correctly - - and your valves ??
  3. REDNECK XXX DISCIPLE
    huntington beach
    The guy that I was talkin to bout It said that for cut exaust an air pods your main go's up 5 an the port go's up 2.5 an the needle diaphram gits raised one an the fuel to air mixture gits adjusted round 2 or so. Im 120 main an 5 sizes up for my carbs are 130.
  4. TIMEtoRIDE
    Well, if that doesn't work, you can always go to a hardware store that has a complete drill index, and drill out your stock jets.
    You can drill and test - - drill and test until you find what works right for your bike.
    Then post-up your results in the thread "Success Stories. . . "
    POD thread here
  5. REDNECK XXX DISCIPLE
    huntington beach
    Ok I check that out. Thanks alot.
  6. REDNECK XXX DISCIPLE
    huntington beach
    H
    e
    Hey I went to the home depot an got a drill kit but the smallest they had was a 1/16 witch is also a 1, 59 mm. Any idea on if thats to big or what I should do from here?
  7. streetbrawler750
    streetbrawler750 Member
    Minnesota
    Way too big. You should be able to tune it without changing the pilot jet if you get a color tune tool it helps immensely. I got a small set of bits with a pin vice from ebay cheap. The size of the jet is the size of the hole, i.e. a 120 is 1.20, I was running a 132 before I changed my set up and that worked well for me. The needle height is something you'll have to get the bike test drivable to dial in.
    REDNECK XXX DISCIPLE likes this.
  8. streetbrawler750
    Minnesota
  9. REDNECK XXX DISCIPLE
    huntington beach
  10. k-moe
  11. REDNECK XXX DISCIPLE
    huntington beach
    Also what size bit case should i git? Is 61 to 80 mm good or what should be my range?
  12. k-moe
  13. REDNECK XXX DISCIPLE
    huntington beach
    I dont really understand how to read the charts. I got a 120 main jet an I wanna go up 5 so should I go to 26 or bigger? An my ports a 40 I was gonna go up 2. or 2.5 so should I go 42 or 43?
  14. k-moe
    The chart I linked to is for determining the size jet you have based on drill size. I thought that you said you were not sure if the jets you have were drilled out or not.
  15. REDNECK XXX DISCIPLE
    huntington beach
    No the jets I got are stock jets but im tryin to go bigger cause I got straight pipes an air pods.
  16. streetbrawler750
    Minnesota
    To go up 5 from stock you would need a 1.25 mm drill bit ten up would be 1.30. The stock Jerry is 1.20 mm.
  17. REDNECK XXX DISCIPLE
    huntington beach
    Ok how bout the port jet?
  18. streetbrawler750
    Minnesota
    You mean pilot fuel jet? I didn't changed mine, was able to richen it enough with the mixture screws. .... that's where a color tune comes in handy.
  19. REDNECK XXX DISCIPLE
    huntington beach
    Is gunson the only one who makes em? The cheapest I can find is 70 bucks for one.
  20. streetbrawler750
    Minnesota
    I believe so. They aren't cheap, but it's one of the best things I've invested in for tuning. You might be able to get it tuned without one, but if you want the razors edge I'd recommend it.
  21. REDNECK XXX DISCIPLE
    huntington beach
    Yeah im probly gonna pick one up just to have it for future. Thanks for your help.
    streetbrawler750 likes this.
