New Build ... little patience
Discussion in 'Hangout Lounge' started by XJoe, Oct 20, 2014.
  1. XJoe
    XJoe Member
    Sioux Falls, SD
    I bought a 82 XJ 650 Maxim on Craigslist with 13800 miles on her in almost perfect shape.
    I will have lots of parts going up for sale very soon
    bars
    gauges
    seat
    rear shocks
    side covers
    headlight
    and more to be listed soon
  2. XJoe
    XJoe Member
    Sioux Falls, SD
    new bars, grips and controls... also started powder coating lots of pieces
  3. XJoe
    XJoe Member
    Sioux Falls, SD
    finding the right height
  4. XJoe
    XJoe Member
    Sioux Falls, SD
    Going with flat black on wheels and forks
  5. XJoe
    XJoe Member
    Sioux Falls, SD
    Engine out ... lots of cleaning to do! Going with VHT high temp pearl black for entire engine... valve cover were powder coated with black wrinkle
  6. Ted
    Ted Member
    Sioux Falls, SD
    Hey Joe - greetings from Sioux Falls! Looks like you got a good start on it there, man. I'm glad to see you got the broken stud situation sorted out & looking forward to seeing your progress.
    The new controls look good - what did they come off of?
  7. XJoe
    XJoe Member
    Sioux Falls, SD
    I ordered the new controls from Dimecitycycles.com I will be relocating my ignition switch down by the battery somewhere along with the choke too. I just received my new mini speedo and tach as well as my 5 3/4" halo headlight too.. I mocked it all up and looks freakin sweet!
  8. XJoe
    XJoe Member
    Sioux Falls, SD
    Finished my front and rear wheels today.... and I figured I am not using my center kick stand ever again... I decided to chop off the ends of it and use them as my new hard tail brackets!
  9. XJoe
    XJoe Member
    Sioux Falls, SD
    Forgot I finished my brake drum too...
  10. XJoe
    XJoe Member
    Sioux Falls, SD
    More powder coating to come... debating powder coating my frame or painting it???
  11. Ted
    Ted Member
    Sioux Falls, SD
    Lookin very good man - I'm jealous! Maybe someday I'll have the time, money, and ambition to do a full tear-down build they way I'd really like it done but until then it's nothing but half-ass budget bobbers for me! :D
    Awesome idea to steal the center stand mounts for your hardtail. That should look pretty sweet.. might have to borrow that idea from you if ever get around to hard-tailing one of mine.
    If it was me and money wasn't the issue I would definitely powdercoat the frame.
  12. mnrider
    mnrider Member
    Minnesota
    Bike is looking really cool. Keep up the good work. It reminds me of mine.
  13. k-moe
    I'm not going to criticize your build, or your personal tastes, but it is a shame to see a great example of an original bike cut up. Surely there were better candidates available (and I'm saying that as someone who does not really like the looks of the stock Maxim).
  14. XJoe
    XJoe Member
    Sioux Falls, SD
    Thanks Ted! Luckily I have a 8' tall 4' wide x 4' deep oven to powder coat almost anything...
  15. XJoe
    XJoe Member
    Sioux Falls, SD
    I came into this trying to find a healthy XJ650 knowing she would be torn down and put together once again in different form.
  16. XJoe
    XJoe Member
    Sioux Falls, SD
    SO... here is the assembly pix... note I still have to weld the hard tail pieces on yet. Frame, wheels.. flat black. Triple trees, kick stand.. powder coated wrinkle black. Engine done in VHT Black Pearl high temp..and the valve covers powder coated wrinkle black.
    20141026_115043.jpg 20141026_115111.jpg 20141026_123141.jpg 20141026_123200.jpg
  17. XJoe
    XJoe Member
    Sioux Falls, SD
  18. XJoe
    XJoe Member
    Sioux Falls, SD
  19. kwes
    kwes Member
    tampa
    niiiiicceeeee! and dime city cycles isnt too far from me they have some cool stuff!
  20. XJoe
    XJoe Member
    Sioux Falls, SD
    Starting on the wiring today... exhaust and engine in place!
  21. XJoe
    XJoe Member
    Sioux Falls, SD
    Carb jetting done ... went with 6-Sigma, now the rest of my wiring to tackle!
  22. ArnoldH3
    ArnoldH3 New Member
    LA
    What does 6-sigma mean?
  23. ArnoldH3
    ArnoldH3 New Member
    LA
    Did u ever end up relocating the choke?
    If so where and how?
    I'm in need of guidance to relocate the choke(enrichment cuircuit) lol
  24. XJ550H
    its a company that sells rejetting kits you tell them how far from stock your bike is and they give you the parts to make the carbs work with your mods
    ArnoldH3 likes this.
  25. XJ550H
    if you click onposters avatar it will tell yoou the last time they were here
    xjoe sept 2015
    Stumplifter and ArnoldH3 like this.
  26. ArnoldH3
    ArnoldH3 New Member
    LA
    Thank you!
  27. XJ550H
    if you can make a longer rod you can move the bracket on the carb hats to the left outer carb and the bracket on the rod on to the outside you can mount a
    bicycle shifter lever on the hat bracket with a short cable or linkage running to the rod bracket
  28. hogfiddles
    Well---
    550 carb enricher cable hooks onto the end of the actuator rod.
    650/750 enricher cable hooks onto the bracket in front of the third carb. That is held in place by a screw/bolt that goes through the rod. In order to relocate that bracket, you'd have to drill a new hole and thread it.
    It's not as easy as 'just relocate it'
  29. k-moe
    And there would be new spacers to make.
    hogfiddles likes this.
  30. KAAL
    KAAL New Member
    San luis obispo
    Looks really good!!! I should just pull mine apart since I'm this far in and do it right.
