85 maxim xj 700 intake boot cant find them anywhere
Discussion in 'XJ Technical Chat' started by hohenstein23, Nov 11, 2014.
  1. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    I have a 1985 maxim xj700 that needs intake boots from carb to engine. I cant find them anywhere online and did not find them in chacals catelog but i could have accidentally skipped over the in there. Is any other bike have compatible parts or something like that. I am looking for new or slightly used so i am not really looking for a repair unless you have a 100% reliable fix. Thank for the help
  2. Orange-n-Black
    Memphis Area
    The XJ700 was only made for 2 years and the boots are as hard to find as hen's teeth. The 700N, 700NC and the 700X all shared the same 33mm carb intake boots. Also the FZ had the same motor as the 700X, so the boots are probably the same as well. So widen your search to list those models.
    So people have used 83 750 Maxim boots as replacement, but that also requires using the 750 carbs since the carbs and boots for the 750 are 32mm.
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
  4. bigfitz52
    Just because you can't find something in chacal's catalog doesn't mean he doesn't have it. ASK HIM.
  5. chacal
    Airhead and waterhead XJ700's use completely different carbs, intake manifolds, and airbox boots. We should have new or good used versions available for either style.
  6. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    Thanks you for the replys
  7. bullheimer
    bullheimer Member
    washington state
    i just finally after two or three months put my carbs in and the front boots went on, i dont want say easy, but on. the back ones, i got them back out of the air box, but they wont go completely back all the way over the circumference of the carb! ITS LIKE THEY SHRUNK!! Man, I'm so pissed!
    What could have happened? would brake cleaner, make them swell alittle? or is that carb cleaner. i could swear that one of them did on the front boots' O Rings, when i was spraying grime off them. maybe that's why the front ones went on.?...?
  8. Rod1
    Rod1 Member
    San Luis, Argentina
    Same problem here, but I'm not even close of U.S.A. to get them fast enough. Were did you get them??
  9. bullheimer
    bullheimer Member
    washington state
    oh brother, XJ4Ever, $80/set for my 85.
  10. Orange-n-Black
    Memphis Area
    You can boil the airbox boots to swell them enough to fit.
  11. bullheimer
    bullheimer Member
    washington state
    hmm. i sprayed brake cleaner on them last night., if that do'n work then into the kettle they go!!!
  12. Rod1
    Rod1 Member
    San Luis, Argentina
    Thanks, I'll look up there...
  13. Rod1
    Rod1 Member
    San Luis, Argentina
    Thanks I'll check it...anyone that have the blueprints of this boots??
  14. Rod1
    Rod1 Member
    San Luis, Argentina
  15. Rod1
    Rod1 Member
    San Luis, Argentina
  16. Rod1
    Rod1 Member
    San Luis, Argentina
  17. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    Chacal at xjforever has the boots but I am not sure he will ship overseas but you can pm him to get the info.
