Tire Valve Stem Size
Discussion in 'XJ Technical Chat' started by MoeSyzlak, Jul 7, 2007.
  1. MoeSyzlak
    MoeSyzlak New Member
    NYC
    Hi,
    I'm replacing my tires and want to change to an angled valve stem for more pressure check/fill clearance. I saw a couple in JP Cycles but they were different size diameters. Does anyone know what the diameter is so I can order the parts before I take my tire off? I've looked in the Haynes manual and the OEM parts schematic but they don't mention any sizes.
    Thanks in advance.
    T.L.
  2. MoeSyzlak
    NYC
    Nothing?
    Any thoughts on how I can measure the one I have on the wheel now?
    T.L.
  3. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    I measured my valve stem and it is .3". So I would think that the 5/16" stem would work. Thing is, it is the diameter of the hole in the rim that should be measured. So we someone with a rim with the tire removed to be sure.
