what did I do wrong?
Discussion in 'XJ Technical Chat' started by ronha13, Apr 17, 2015.
  1. ronha13
    ronha13 Member
    Curtiss Wisconsin
    put the new clutch in and reassembled everything.
    now I can't squeeze the clutch....
    is my torque wrench not working and bolts too tight on the springs?
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Does the clutch have complete throw out?
    Gary H.
  3. ronha13
    ronha13 Member
    Curtiss Wisconsin
    can put in gear without clutch - but wont move - I did something wrong
    First clutch I've done in over 40 years
  4. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
  5. ronha13
    ronha13 Member
    Curtiss Wisconsin
    85 xj700 ... sorry, forgot that part. :p
    I will pull it apart today and take a look at it again.
    probably something simple I missesd.
  6. k-moe
    Did you line the dots up?
    The pressure plates on the 650/700/750 are different. There is no special locating tab, clutch boss spring, or special friction plate.
  7. co.ko
    co.ko New Member
    Florida
    How much did you remove in the tear down? Did you remove the center nut and spindles the plates sit in? Sounds like it is being pulled to far when putting the lever and cover back on.
    I have the same bike, N model. Just bought it about a week ago real cheap. Guy before me took all kinds all stuff apart and, naturally it was dirty and worn out. I ran through everything, got er running. Now im having about the same problem as ronha13 but opposite. I pull in on clutch and it dosent seem like the lever pulls far enough.
    the only plate with a mark on it is the outermost has a half circle cutout on one tab and the cover has a dot that lines up underneath.
    There is aslo a bit of slack on the gear shaft the lever pulls on.
    New user, first time post thanks in advance. Love the site, been a huge life saver the last week.
  8. k-moe
    You need to remove that slack. Rotate the throwout arm clockwise until it stops, then adjust the cable so there is no slack at the clutch arm end. Adjust the lever end so there is 2 to 3 mm of free play at the lever.
  9. co.ko
    co.ko New Member
    Florida
    I pulled the center nut and spindle the steel plates sit on today. IDK what the fella before me did cause i just cleaned it up put er back on and everything works fine now.
  10. ronha13
    ronha13 Member
    Curtiss Wisconsin
    Thanks k-moe..... you hit the nail on the head :)
  11. k-moe
    Only after years of practice hitting my thumb.
  12. ronha13
    ronha13 Member
    Curtiss Wisconsin
    lol :p
