82 Xj750 Maxim Build
Discussion in 'XJ Modifications' started by Joshua Tate, Apr 22, 2015.
  1. Joshua Tate
    Joshua Tate New Member
    Tampa Fl
    Just going to tweak my bike some. Mods along with painting and good elbow grease scrubbing. Not a solid goal in mind. Just seeing where it takes me. I just like filling my time with something I love. The pics here are of the bike as is. I didn't put the pods on and the side panels were missing when I bought it. Only 24,000 miles. It was my daily driver for the last 2,000 miles and now that I have some time to work on it, it is time to make her feel beautiful.
    Mods so far
    1: The only thing I have done so far is twisted/bagged all the electronics and battery tray around and tucked into the old air-box area so the Florida rain wont ruin my day.
    2: Removed the auxiliary light that didn't run and wired the primary light to the switch so I can turn it on and off.
    3:Removed the main stand that had no spring return and wont be used.
    4: Removed the safety's for the clutch and side stand. So don't start it if you are not being careful!
  2. k-moe
    One of those mods is going to get you a ticket.
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Is it the pods?
    Just kidding... Nice looking bike!
  4. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    The light?
  5. Joshua Tate
    Tampa Fl
    Which one will get me ticketed? I am thinking the light also. Probably if I forget to turn it on a dusk. I will wire it back up when I put the new one in. For now I am getting some kind of battery drain from that part of the original harness so I just bypassed it until I can get in there. Being my daily driver up to his point I had to stick to small quick fixes.
  6. k-moe
    Yes the light. All motorcycles sold in the USA after 1978 are required to have a headlight that is on whenever the engine is running.
  7. Joshua Tate
    Tampa Fl
    Good looking out.! I'll pull out my multimeter and rectify that soon.
  8. hogfiddles
    Yes, the light switch mod CAN get you a ticket, but only if you don't get in the solid habit of turning it on every time you start the bike. If you turn it on every time, then there's no worry about a ticket cuz the light will be on. HOWEVER, all you have to do is forget to turn it on ONE time......and have THAT be the time that a cop spots you.
  9. Polock
    that switch for the aux light might not handle the current for the headlight. i think the aux light was 35 watts and a high beam is like 60 or 65. so keep a eye on that. if the right grip starts smoking, you'll know what happened :)
  10. FtUp
    FtUp Well-Known Member
    pacific northwest
    in some states, it is a law that you run with the high beam on during daylight hours too. and just a good idea imho.
    FU
  11. hogfiddles
    Wow... That's a new one to me---!
    But I know a lot of people here run with their high beam on all the time, even at night. I always try to turn to low for oncoming cars, but if I forget.... Oh well they'll see me. But when I'm in the car or truck I try to be religious about not high beaming anyone
  12. MattiThundrrr
    I drive a car that's pretty low, and high beams practically blind me, either oncoming, or following me. Even low beams with the HID lights are pretty bad. Stock ride height Civic, but everybody around here drives trucks. Riding position on the Seca is much higher. I drive with the headlights on anytime I would think of using the wipers. Reduced visibility = reduced safety!
  13. Joshua Tate
    Tampa Fl
    I'll check the wattage for sure. I don't currently run high beams all the time because I always wear a super bright miners head lamp, even on the brightest days. =] JK. About the always high beams, I do prefer to be visible annoying over dead.
  14. spud
    spud New Member
    western australia
    hi everyone! im a noob to this site. i have a 1986 xj 750 p and would like to turn it into a cafe/brat style type of bike my question is do i need to customize the frame to have a flat style seat. thanks
  15. Joshua Tate
    Tampa Fl
    Update.
  16. Joshua Tate
    Tampa Fl
    Max is five it seems.
  17. Joshua Tate
    Tampa Fl
    Last one.
  18. cutlass79500
    lawrenceville georgia
    Looking good just finished my 83 just have to go get it registered .
    Joshua Tate likes this.
  19. k-moe
    You don't need to do anything to the frame. The stepped seat is a function of how the seat pan is made, and also to the shape of the underlying foam. You can have the seat rebuilt (or do it yourself) to make it flat. One caveat: the seat will have to be either higher in the front (more padding for you), or lower in the rear (less padding for the lady).
  20. MattiThundrrr
    Not every time... I just saw two doods on a CBR125. Seriously. a 125. that's barely enough engine for one dood!
    Bike is lookin good, Josh. It's starting to come together... You must be itching to hear it purr!
  21. Joshua Tate
    Tampa Fl
    Thank you. A 125?! That is not enough engine for two dudes lol!! I really enjoyed rebuilding the new harness, even with all the headaches. Next winter I'll drop the engine and rebuild it from the bottom up, while its out strip and paint the frame as well. On a side note, when I cut the housing from the harness that runs down the left side of the tank It was full of water.... No shorts and I replaced all the wires but that was not comforting.
  22. saftie
    New York, NY
    Water in the harness seems to be a common thing It seems. Had a 650 and now a 550 and both had water in there but never affected anything...
    is that a label machine thingie magicky? I need to get me one of those. Blue markers tape and pen doesn't look nice, even if it's just temporary. I can never read my own writing on there after a while.
  23. Joshua Tate
    Tampa Fl
    Yeah, I have two actually. I use one for regular marking, then I have one loaded with weather proof tape! So I just leave the labels on the vital connections. Now when I forget whats what its all right there.
  24. YamaMax82
    YamaMax82 New Member
    Oakland, CA
    Its great to see, someone is making their 82 maxim look nice. I have the same project going on with my 82 too. Good luck and have fun with it.
