wheel balancers
Discussion in 'XJ Technical Chat' started by hubie, May 9, 2015.
  1. hubie
    hubie New Member
    Minneapolis
    Does anyone have any recommendations for a good wheel balancer. I've seen them range from around $25 to over $100. Any suggestions are appreciated.
    Thanks.
  2. bomber737
    bomber737 Member
    New Richmond WI
    I have used the one from harbor freight. It's descent quality and comes with a stand.
  3. k-moe
    An old axle, two good axle bearings, and two jackstands.
  4. XJOE550
    XJOE550 Active Member
    Inverness, FL
    Has anybody used balancing beads? Maybe that's an option. But I'm not completely sold on them.
  5. k-moe
    I've done a fair amount of research. Beads are not an option. They do not take into account the motion of the tire as it goes over road irregularities. Every bump upsets the beads ability to balance the tire. The sellers will point to the use of beads and fluids in dynamic balancing sytems in industry and consumer goods (washing machines for example), but the sellers ignore the fact that those are stationary applications that only have to balance axial loads.
  6. XJOE550
    Inverness, FL
    Thanks k-moe. Great info!
  7. hubie
    hubie New Member
    Minneapolis
    When you say an old axle, and bearings, are you referring to an axle from a similar bike, and bearings?
  8. k-moe
    Yes, but new bearings without any dust seals. Lube the bearings with silicone spray to reduce drag.
  9. hubie
    hubie New Member
    Minneapolis
    New bearings in the wheel, correct?
  10. k-moe
    New wheel bearings to set on the jackstands and hold the axle. The goal is a minimum of parasitic drag so that you can find the heavy spot, and have the heavy spot settle in the same location no matter where it is.
  11. Polock
    first thing to do is clean the rim, then balance the rim by itself, mark the heavy point of the rim and put the tire dot by your mark when you mount it. I've never found the valve stem to be the heavy point of a rim. This way you might only need a very small amount of weight.
  12. hubie
    hubie New Member
    Minneapolis
    Thanks for the info!
