1982 XJ650RJ Tach cable replacement
Discussion in 'XJ Technical Chat' started by colinski6, May 16, 2015.
  1. colinski6
    colinski6 Member
    Gig Harbor WA
    Anyone know what the part number is for a new tach cable for my 82 650 Seca U.S. model?
    I bought a motion-pro 05-0010 but the threads where it mates to the engine are female instead of male.
  2. Seca rider
    Seca rider New Member
    Fremont, CA
    HCP 2727 from Chacal @ xjforever.com. Click on the link at the top of the page. He will get you the right part fast.
  3. XJ550H
  4. Toomanybikes
    Tsawwassen bc
    To colinski6
    4k0-83560-0000 same as euro model unless someone swapped engine or head or your missing threaded part that cable attaches to item 5 in pic. Did you toss it out with old cable If that is missing the shaft seal may be missing as well.(item 4) Oem cable should be female both ends item 4 still available item 5 not but the part originates from the xs650 twin so very easy to find
  5. Toomanybikes
    Tsawwassen bc
    In Canada we got both engine types early one mechanical tach later ones electronic tach. I got a new one in fall of 1981( so long ago) from early batch we got only silver bikes non YICS
  6. chacal
    Toomanybikes is correct, the tacho cable should have a female end at the engine, there is a male threaded piece that fits into the tach drive housing that must be missing (check the end of your old cable if you still have it!).
  7. colinski6
    colinski6 Member
    Gig Harbor WA
    Oops I feel like an idiot. The short male threaded piece came out with the cable when I took the old cable off, and it never occurred to me that it was separate from the cable.
    On a side note, when I got the bike the cable housing was in place, and looked fine, but the drive cable was missing.
    Thanks everyone for the help! I've been really busy lately
  8. hogfiddles
    Ribo suggested Rum.....that might help-----
  9. Toomanybikes
    Tsawwassen bc
    As for hard stuff I'm a Southern Comfort guy 3 ice cubes and just float them
