82 XJ550 Part Out
Discussion in 'For Sale, Trade/Swap, Wanted' started by joepaul85, Jun 10, 2015.
  1. joepaul85
    joepaul85 New Member
    Butler, PA
    I'm parting out my 82 Xj550. 2nd gear was shattered so there was metal in the oil change 3 times over. Trying to get that cleaned engine rebuilt and other things I would need to get it running again I'd be way upside down on it. I'm trying to save face and get something outta it. I know this will kill some, ok alot, of you fellow members, but this is what I believe to be best. Like I said 2nd gear was shattered so metal in the oil pan through the engine. But those at your own risk. Other parts on the bike should be there as I was able to ride it a total of 3 times before it stopped shifting into second gear. Sad part this was my first bike, so might of left me with a bad taste in my mouth. But I'll try again, just with a different bike. I'll ship parts, but at your expense. I'll do my best to save you on shipping, but I'm not Amazon Prime. Thanks for looking, and possibly your interest in some parts. 20150610_203748.jpg 20150610_203856.jpg 20150610_204022.jpg
  2. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Crappy deal, buddy... hope you can recoup some of your loss.
  3. joepaul85
    Butler, PA
    I have the plastics that cover the battery and the air box also. I took them off when I was charging the battery. One has a bullet hole sticker from the PO covering some of the "chrome" flake from peeling. I can post pictures of those tonight when I get home.
  4. EarMachine
    EarMachine Member
    Deep River, Ontario, Canada
    Where are you located?
    I'm in need of a left side plastic cover and possibly some other parts.
    Also sorry to hear about what happened :(
    -EM
  5. joepaul85
    Butler, PA
    I'm in Butler, PA. Its about an hour North of Pittsburgh. Sorry I haven't posted the pictures of the side covers. I will do it tonight.
  6. EarMachine
    EarMachine Member
    Np. Pm sent.
    -EM
  7. Jake519
    Jake519 New Member
    Ontario, Canada
    I may be interested in the airbox as well as a couple of other things. I'll send you a pm.
  8. XJ550H
    have you considered a motor replacment?
  9. joepaul85
    Butler, PA
    No. I'd be losing more money if I replaced anything more on it.
  10. XJ550H
    how much for the speedometer hub and cable? possibly speedometer too?
  11. joepaul85
    Butler, PA
    Cables are gone sent pm about hub & speedometer.
  12. joepaul85
    Butler, PA
    Are we allow to bump our posts?
  13. EarMachine
    EarMachine Member
    Lol I'll help you bump. I got some parts from joepaul85 and everything came very quickly and exactly as described.
    Thanks again man!
    -EM
  14. mstubbs726
    mstubbs726 New Member
    Boulder, CO
    PM on relays sent
  15. jokidd82
    jokidd82 Member
    Indidnapolis, IN
    how much for ignition coils and caps.
  16. joepaul85
    Butler, PA
    Didn't get scolded last time for bumping my post, so I'll do it again.
    *Bump* haha
    Still many things left. I had a fellow local Xj'er offering to take the whole thing off my hands. But I'd like to help out as many people as possible.
  17. dillion
    dillion Member
    LasVegas
    still have the tank?
  18. joepaul85
    Butler, PA
    Yea I still have the tank, here are some pictures.
  19. dillion
    dillion Member
    LasVegas
    how much are you asking is it rusted on the inside? any leaks?
  20. joepaul85
    Butler, PA
    Sent Pm.
  21. Gregg Bowen
    Gregg Bowen New Member
    East Dundee IL
    Do you have the front brake lever and shifter?
    If so, how much?
    G
  22. Gregg Bowen
    East Dundee IL
    Or perhaps the whole front brake (lever, master cylinder, caliper)?
    G
  23. joepaul85
    Butler, PA
    Front Brake & Clutch Lever are gone. Shifter is available, I'll double check for the Master Cylinder and Caliper, thinking they are on there. I will send you a pm tonight.
    Gregg Bowen likes this.
  24. kirklandxj550
    kirklandxj550 New Member
    kirkland wa
    Need airbox assembly, and maybe the carb setup, chain and sprocket, petcock, master cylinder, brake lines, and seat
  25. kirklandxj550
    kirkland wa
    Also exhaust system and wheels and tires possibly and rear shocks..... I just got a 83 550 and its been siiting for 20 years so if the price is right i could use a bunch of stuff
  26. Mnoehre
    Mnoehre New Member
    Oswego,IL
    I need the two black plastic fork caps that cover the air valves. Still available?
  27. hogfiddles
    Kirk, I have an exhaust system---
    Mnoehre, I think I might still have a set of fork caps-- I'll check tonight
  28. joepaul85
    Butler, PA
    I messaged them both, didn't hear back from either of them.
  29. Rmwillison88
    Rmwillison88 New Member
    Carrollton ohio
    I need a frame with a clean title I just got the bike and found out I was screwed over I've got a broken frame. How much would you want for the frame and title, I'd be interested in a few other parts also
  30. joepaul85
    Butler, PA
    Sent PM Rmwillison88
  31. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I need a turn signal assembly. Front left but they may all be the same?
  32. dgroot
    dgroot New Member
    Colorado
    I need a right side handlebar control assy (the one with RUN OFF RUN and starter button). Still available and does it still have starter button?
  33. joepaul85
    Butler, PA
    I do not have that part anymore. Sorry.
  34. chrisserianna
    chrisserianna New Member
    Knoxville
    Right side cover available!? I've been searching everywhere
  35. joepaul85
    Butler, PA
    Already sold. Sorry.
  36. joepaul85
    Butler, PA
    Just wanted to let everyone know that I sold the remaining parts of the bike, and this thread can be closed. Thanks!
  37. hogfiddles
    In that case, anyone still looking for parts can contact me.... I have a bunch of 550 parts, and some listed in my thread in the "for sale" forum
    Dave F
