I'm going crazy!!
Discussion in 'XJ Technical Chat' started by Xj Bobber, Jul 13, 2015.
  1. chacal
    deleted
  2. Xj Bobber
    Xj Bobber Member
    ohio
    What is this?
  3. zombiehouse
    zombiehouse Member
    Pomona, Ca
    Check to make sure that the alternator brushes are in spec.
  4. Xj Bobber
    Xj Bobber Member
    ohio
    do you know what the specs are for them?
  5. Xj Bobber
    Xj Bobber Member
    ohio
    shes a work in progress
  6. k-moe
    There is a wear limit groove on the side of each brush. You should also take a hard art eraser and polish the slip ring (the copper traces that the brushes run on). Otherwise there is no maintenance to do. Your picture looks like a normal alternator rotor. They were not built to be pretty to look at.
  7. Xj Bobber
    Xj Bobber Member
    ohio
    On my way home this morning my battery died and i was stranded on the side of the road. I had to walk my bike about a mile and a half to my buddy's work and dropped it off and had my wife come get me. So could there be a possibility that my alternator is not charging my battery?
  8. Xj Bobber
    Xj Bobber Member
    ohio
    Well i guess the right question to ask is has anyone had one go out or heard of one going bad?
  9. k-moe
    Yes your alternator might not be making enough voltage, or your voltage regulator could be bad, or your battery could be unable to take and hold a charge, or....
    See where I'm going?
    This will require diagnosis.
    This thread should get you started on that process (be sure to read the links too) http://xjbikes.com/forums/threads/charging-system-testing.43766/
  10. Xj Bobber
    Xj Bobber Member
    ohio
    Ok thanks
  11. Xj Bobber
    Xj Bobber Member
    ohio
    Can everyone see the pictures of my bike I put in this thread?
  12. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    I can
  13. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    I can see it . . . but if it don't run . . . . . . :confused:
    See a lot of mods to it, including pods and chopped mufflers. What I have gleaned here is that a stock bike is easier and more predictable to tune/ troubleshoot.
    Good luck!
  14. k-moe
    You need mufflers. I don't mean that it woud be nice if you had some, I mean that you NEED them. Power delivery is crappy without.
  15. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Buy a new battery & eliminate that from the equation........
  16. EarMachine
    EarMachine Member
    Deep River, Ontario, Canada
    Some of you wise xj owners are so patient.
    Lol
    -EM
  17. fiveofakind
    San Diego, CA
  18. fiveofakind
    San Diego, CA
    better pic of alternator brushes showing wear limit indicators...........
    Steve R likes this.
  19. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Although this is a better pic i can see them just fine in the first photo. Nice pics.
    Gary H.
  20. Xj Bobber
    Xj Bobber Member
    ohio
    Thanks guys. i got the bike without mufflers they dont have to be stock right? Is it all in the length for the back pressure like a car?
  21. Xj Bobber
    Xj Bobber Member
    ohio
    Is there a special way that the alternator cover has to come off? i feel like im going to rip some wires when i gently pull on it.
  22. XJ550H
    slide the rubber gromet out of the shell where the wires run through it it will give you a little more play
  23. denbola
    denbola Member
    poole,dorset,england
    has anyone tested the wiring to the engine stop switch?
  24. denbola
    denbola Member
    sorry for the last up guys missed a couple of pages
  25. Xj Bobber
    Xj Bobber Member
    ohio
    Should this be about 12 volts?
  26. Steve R
    Steve R Member
    Kansas
    Some advice, I have full output voltage above 2,000 rpm's 14.40 volts. At idle it is running on the battery. Starts at 12.6 then slowly drops to 12.30. I tested the stator and they are in spec, .45 ohms give or take 10%. Also tested the rotor and they are in spec, 4.0 ohms give or take 10%. I have 50,000 miles on it and i am pretty sure the brushes have not been changed. Peace of mind i will change the brushes. Have not checked the regulator yet. Brushes or regulator??need changing or both?
  27. XJ550H
    from this link
    "For all XJ-series models, the maximum available charging output VOLTAGE should be as follows (all values are approximate):
    * approximately 500-2000 rpms: 1.8 volts gradually increasing to 14.2 volts
    * 2000+ rpms: 14.2 volts up to about 14.8 volts, with a maximum of 14.8 volts (all models except XJ700-X and XJ750-X)
    * 3000+ rpms: 14.2 volts up to about 14.8 volts, with a maximum of 14.8 volts (all XJ700-X and XJ750-X)
    If your charging voltages are too low, suspect the alternator brushes first, then perform the alternator stator and rotor checks as described in the Alternator Section.
    Note that worn, dirty, or damaged alternator brushes can affect these readings, as can "dirty" copper commutator rings on the rotor face (where the brushes contact the rotor):"
    clean rings with a eraser
    could be the brushes there is a wear mark on them should be iirc 17mm to 11mm
    clean battery terminals and ground connection to frame and motor from battery wire
    and any other connectors in the charging system take a good look at the voltage regulator connectors
  28. XJ550H
    I read on another yamaha site that if you go stright pipes go short not long
    I will look for that site and post it here.
    but mufflers are better
  29. quebecois59
    yeah, mufflers are better for your bike and for your neighborhood too.
    Steve R and k-moe like this.
