Took my shifter casing off and now no spark at all 4 plugs.82 XJ650
Discussion in 'XJ Technical Chat' started by morg65, Jun 20, 2015.
  1. morg65
    morg65 Member
    Dublin Ireland
    Hi gang,
    Long time no hear. Nearly 2 years ago my XJ jammed in 1st gear and I had to get a recovery truck home.
    So long story short,yesterday I finally got around to checking it out and found the dreaded chunk of hard plastic in the casing but not in the drum. She seems to have freed up now and i can select all gears but now the problem is no spark at all. I did notice that we accidentally split the wiring which tucks in towards the bottom left of the casing which exposed three wires, orange, grey and black. Taped them up but I am making an assumption that perhaps this is the reason I have no spark at all now. I think these wires go to the pick ups but any advice will be great.
    As always thanks .
    Morg.
  2. Polock
    the black wire is common to both pickups and should not be connected to ground. black to orange and black to gray should be about 650 ohms. unplugged from the tci none of them connect to ground
    ryon likes this.
  3. ryon
    ryon New Member
    Salem/Lebanon OREGON
    will bad pickup or mis connected pick up coils cause NO SPARK AT ALL?
  4. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Absolutely! If the TCI doesn't receive the proper signal from the pickups, it won't fire the coil to the sparkplug.
    ryon likes this.
  5. ryon
    ryon New Member
    THANK YOU!
    what would be the best thing to use to clean the surface rust off of the pickup coils faces? i would like to clean and test before i buy a new one....
    THANK YOU IN ADVANCE!!
  6. k-moe
    Nothing! Surface rust will not cause any trouble, but cleaning the pickup coils might.
    Before jumping to conclusions you need to be doing some electrical testing to determine what is going on.
    Do you gave power to the TCI?
    Do you have power to the ignition coils?
    Is the safety relay functioning?
    Test the resistance of the pickup coils.
    The list is longer, but that will get you started.
    ryon likes this.
  7. ryon
    ryon New Member
    no power to TCI
    power to ignition coils
    saftey relay stopped working all of the sudden and i used a test light and it barely lights up (bad connection?)
    pickup coil resistance seems awful in comparison to what a guy on youtube showed
  8. k-moe
    Don't look for advice on Youtube (unless it is a video that is linked from this site).
    What was the pickup coil resistance?
    How is your sidestand switch? Does it move smoothly? Is it hooked up?
    Do you hear a click from the safety relay when you turn the key on?
  9. ryon
    ryon New Member
    22k ohms
    there is no side stand switch for the year I have (1981)
    the click from the relay used to happened until I started getting low dc voltage output on it (out of nowhere) is there a way to bypass it safely
  10. k-moe
    At this point it would be good for you to start your own thread. The differene in year between your bike and the OP's bike may continue to cause confusion.
    ryon likes this.
