Morgan carbtune hookup
Discussion in 'XJ Technical Chat' started by Myron, Jul 28, 2015.
  1. Myron
    Myron Member
    Winnipeg, Manitoba, Canada
    Hi guys. Am attempting to sync my carbs with the carbtune pro from Morgan. Morgan has included 6mm adapters for my bike, but my hayne's manual says to remove the vacuum caps from the carbs and connect my hoses there. Any thoughts from anyone who's done it.
  2. Beekman
    Beekman XJ Grasshopper
    Erin, Ontario
    You will want to connect the hoses to the vacuum caps on the carb to engine boots i believe. Ive never used one but ive seen a video where the adapters are used to screw into a vacuum port on the carb body (an 80's honda i think it was on) not the vacuum ports on the boots. I dont think our carbs have such a vacuum port on the carb body itself.
  3. Polock
  4. Myron
    Myron Member
    Thanks. Just want to make sure that's where I'm supposed to hook it up. Sounds right and looks right. Just wondering about the adapters.
  5. Myron
    Myron Member
    Polock, I got a tank off my snowblower with a fuel valve. Was gonna use it, but my battery is dead. Won't charge, so I guess a new battery is coming.
  6. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    I made a makeshift gas tank out of a powerade bottle with a hole drilled into it
    and then I put my gas line in and sealed it with rvt
    let it sit for a few days.. works and is cheap
    the morgantune is amazing
  7. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    If your quick you can sync with just the gas in the carb bowls no need for a auxiliary gas tank.
  8. k-moe
    Yep, but only if you warm the bike up before pulling the fuel tank off.
  9. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    The adapters slow the vacuum pull. Other bikes, like Honda, have a place to screw the adapters...Xj's don't. I modified a set of dial gauges and use this...
    Gary H.
  10. k-moe
    Doesn't the Morgan Carbtune come with restrictors that get slid into the tubes? AFIK the adapters are just for hooking the tubes up to those carbs that have threaded vacuum balancing ports.
  11. Myron
    Myron Member
    You are correct K-moe about the restrictions and the adapters. I was just cofused because someone explained that I would have to remove some screws and use the adaters for the hookups. Now I know about the inlets on the intakes.
  12. KA1J
    KA1J Member
    Groton, CT
    I have the carbtune and love it. I got a gas tank off a junk lawnmower and put a brass/ clear plastic filter in the fuel line just to be safe. When carbtuning, I put the can on my seat and bungee cord it in place and it works great that way.
    You have to use the restrictors or you'll get large pulses with each suction, the restrictors make the surge minimal so the reading is smooth. Doesn't matter what the numbers are or how high the rods go, it's all relative & you just want enough height to make a good balance on all four cylinders. Mine read at maybe 1.5" - 2" high.
  13. Myron
    Myron Member
    Thanks. Trying it now. Hooked up fuel tank and turned on tap. Getting fuel leaking out of airbox overflow tube. Did I do something wrong with my carbs? Stuck floats perhaps. Had bike running prior to this.
  14. k-moe
    Did you take the carbs to The Church of Clean, or did you just leave the carbs alone?
    Yes you probably have a stuck float, or a float needle that isn't seating, or a faulty float needle seat gasket, or.....
  15. Myron
    Myron Member
    Yeah. Went to the church of clean. Was very particular about it. Looks like I'm going back to church. Lol.
  16. k-moe
    Did you put an inline fuel flter on? You might just have crud from the tank stuck between a needle and seat. A rap on the bowls with a screwdriver handle might do the trick if the float is just hung up. Did you pay attention to the down-stop tabs on the floats?
  17. Myron
    Myron Member
    I haven't put a filter on yet. Was on my list of to do things. Trying to get it running first. Will find out later this weekend what's up. Got new battery and clutch cable. Hopefully nothing too involved. Will post once I know. Certainly will try the screwdriver handle. Was my first carb rebuild. Honestly do not remember about the down stop tabs.
  18. Myron
    Myron Member
    Well, tapping on the bowls stopped the leak. Thanks K-moe. Now, however, I can only get bike to fire intermittently. Will not stay running. Killed battery trying, so now back on charge. Will try again tomorrow.
  19. k-moe
    You probably have crud from the gas tank that has been sucked into the carb and blocked the idle jet. Pull the carbs, drop the bowls, and give them a good flushing out. Then get yourself a sintered bronze fuel filter to put inline before the fuel rail inlet so that doesn't happen to you again.
  20. Myron
    Myron Member
    Will do. Thanks.
  21. Rooster53
    North, FL
    This is important too, as the float needle valve can hang up if they are pulled too far down by an empty bowl. Unfortunately, I have never seen a spec or a post on suggesting the proper adjustment of the down stop. Some of the members also suggest the closed loop as compared to the open loop wire on the float needle valve.
  22. Myron
    Myron Member
    Hopefully will have time to open it up today and find out. Would love to go for a ride sometime this summer. Winter comes too soon in my part of the great white north. Lol.
  23. rocs82650
    Middle Tennessee
    There is a bend in the down stop. The adjustment is when the face of the bent flange is flat against the float tower. Yamaha installed closed clips (they are better). The open clips tend to spin and get hung on the front of the tang. If using open clips it is suggested that turning the open side of the clip toward the air box will help minimize the hanging.
    Gary H.
  24. k-moe
    Some of the open clips are long enough that a slight bend can be put into the open end so they mimic the action of the closed clips.
  25. Myron
    Myron Member
    Went back to visit church of clean. Had to wait for new carb bowl gaskets. All clean and back together. Bike runs now and idles. Went for a quick run. All seems good. Man this thing can move. :D Tomorrow, carb sync and colortune.
