Clutch problem what all to replace
Discussion in 'XJ Technical Chat' started by hohenstein23, Aug 16, 2015.
  1. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    No matter how much adjusting you do the wheel always spins. I figured that I probably have to do the plates and the springs. I dont know how many different types of plates are actually in their thoughts. Like friction plates and plain plates. I found this on eBay I heard ebc is a good brandhttp://pages.ebay.com/motors/link/?nav=item.view&id=281062514927&alt=web then I also find springs
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Basic rebuild include friction plates, springs, bolts, cover gasket and fresh oil. Imo ebc is good but make certain they are proper for your bike. Fyi Len also sells everything you'll need.
    Gary H.
    Have you removed the shifter cover for a visual inspection?
  3. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    But do you think that basic rebuild would fix the problem. I had the cover off earlier in the year but not lately. Are all the plates the same in their
  4. k-moe
    If the machine is in gear, and the clutch is adjusted correctly, and the clutch still slips then you need to rebuild your clutch.
  5. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    Ok the bike does slip in gear no matter how you adjust the cable. Does the link I posted have all the plates I need
  6. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    ok i took it apart today and the plain plates were deeply engraved to much to just polish them up so all the plates are getting replaced. so are the springs and the gasket. why do people usually replace the bolts i will if i have to but they look brand new no where closed to stripped or is it because of different reasons.
  7. XJ550H
    bolt replacement is because of the high stress they are under and is good pratice.
    its like when you change the head gasket in a car your supposed to replace the bolts, stresso, or the washer on your oil drain plug or the crush washers on your brake lines good pratice
    edit do to reading your post
  8. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    Ok that was what I was looking for I will add the list
  9. XJ550H
    you only want to do the clutch once, would be a bitch to have to do it a second time for a broken bolt.
    its like going to the church of clean and sitting in the back row instead of going up to the altar
    Stumplifter likes this.
  10. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    Yeah I took a lot of shortcuts before I started reading alot and I really regret ed it. Do you know if they are special bolts are just a hardware store bolt
  11. XJ550H
    look at the end of the bolt on the head see if there is a grade number on it. I would purchase them from xj4ever or a dealer . the bolts in a hardware store may not be strong enough.
  12. Polock
    You don't need to replace the bolts.
    Their only tightened to 7 ft/lbs, their not stressed or they would not be 6mm bolts
    Or at least higher grade bolts.
    Everyone changes them because somebody a long time ago said to.
    But hay, their cheap.
  13. Johnius
    Johnius Member
    Detroit
    As someone who had to pull his clutch three times due to broken bolts, you should probably replace them all. They're super easy to get out of you do break one, but it really isn't worth the hassle.
  14. Polock
    Wow, three times. What do you think is making these bolts break?
  15. Johnius
    Johnius Member
    Detroit
    Someone didn't set his torque wrench properly.:confused:
  16. Polock
    I've done that myself but it wasn't the bolts fault
    Johnius likes this.
  17. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Order your parts from XJ4Ever, tell him your bike and what you need, he WILL get you everything you need, no guessing. Often times on e-bay the pictures and descriptions are not what they appear to be. Don't mess with that malarkey - talk to Len/ Chacal.
    Trust and believe for I speak the truth.
    Johnius likes this.
  18. KA1J
    KA1J Member
    Groton, CT
    I 100% agree. Len is your XJ friend when it comes to honesty, accuracy and availability of parts. I've bought from him many times and he has been the go-to person from the beginning. FWIW:An order he fulfilled is in the mail to me at this moment.
    Gary
