New XJ owner here!
Discussion in 'Hangout Lounge' started by a216vcti, Sep 3, 2015.
  1. a216vcti
    a216vcti New Member
    Middle River, MD
    I just bought the bike. I paid a total of $100 for a 1981 built (82 model) XJ550 Maxim. I probably paid too much. I plan on cutting it up and either doing a bobber or a cafe racer. I'm hoping that I can do the cafe racer if possible. I was hoping the frames were the same between the Seca and Maxim or if there is an easy way around that. I wanted to build something very similar to this:
    https://instagram.com/p/5w8e3-p3v-/?tagged=xj550
    The bike looks like this at the moment:
    http://imgur.com/a/5QhGy#0
    She needs a lot of love in order to get her running. I was planning on doing the pods just like in the instagram pic. Does anyone know where to get carbs?
    Also, if anyone is in the Baltimore, MD area, I'm the moderator of a group called bmoremoto. Look us up on facebook and reddit.
  2. a216vcti
    a216vcti New Member
    Middle River, MD
    Also, I didn't get the key. Don't worry, it's not stolen, I have the title and everything. The guys was just very unorganized, to be polite.
  3. XJ550H
    you will need to buy a blank and have a locksmith make you a key, unless you find a Yamaha dealer who kept the old key book. there is a number on the bottom of the ignition switch the letter is your blank type.
    many bikes used the same key number
    this link may have your key
    http://www.ebay.com/itm/Precut-Vintage-Yamaha-Motorcycle-Key-1100-4800-A-F-/170663950511
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I can't see the pic of your bike. Are the carbs missing? Do you have the stock airbox still? Things will be waaaay easier if you stick with the airbox to get it running, and then once you have it working properly, make your changes then. The pods make getting it dialed in more difficult. Here's some light reading:
    http://www.xjbikes.com/forums/threads/the-information-overload-hour.27544/
    If the pods are a must, check out this:
    http://www.xjbikes.com/forums/threads/success-stories-of-pods-and-4-into-1-exhaust.29381/
  5. Toomanybikes
    Tsawwassen bc
    Unless he has a box of parts carbs are not there but airbox is minus boots!
    Bike has been pillaged for parts no switch clusters,headlight. Seat looks ok
    But price is about right, but with no carbs is the engine stuck??
  6. a216vcti
    a216vcti New Member
    Middle River, MD
    Yeah, the carb didn't come with it. The previous owner said he gave them to someone to clean and never heard from the guy again. I'm not sure if the engine is stuck, I'll probably jump the starter to see if she moves.
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Don't. Remove the left crankcase cover and use a 19mm wrench to rotate the engine CCW. If there is any resistance stop trying to turn it. Welcome aboard.
    Gary H.
