1985 Maxim Xj700n compression test
Discussion in 'XJ Technical Chat' started by Alex mathieu, Sep 14, 2015.
  1. Alex mathieu
    Alex mathieu Member
    griffin ga
    I've just done a compression test. These are the results-
    Cylinder 1- 164
    Cylinder 2- 163
    Cylinder 3- 159
    Cylinder 4- 164
    Bike was cold, haven't run it today. Full throttle. Tested correctly. Are these numbers in spec. Bike has 40,000.
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    My service manual says 156 min and 171 maximum. I'd say that you are in great shape.
  3. Alex mathieu
    Alex mathieu Member
    griffin ga
    Would that mean that my valves are in spec? Considerably, I haven't checked in a good min.
  4. XJ550H
    from http://www.xjbikes.com/forums/threads/the-information-overload-hour.27544/
    where all your test specs can be found
    650, 750 air-cooled engines:
    Minimum: 128 psi
    Standard: 156 psi
    Maximum: 171 psi
    Max. variance between lowest and highest: 14 psi
    700 non-X (air-cooled) engines:
    Minimum: 128 psi
    Standard: 156 psi
    Maximum: 171 psi
    700-X and 750-X (water cooled) engines:
    Minimum: 154 psi
    Standard: 159 psi
    Maximum: 165 psi
    Max range allowable between highest and lowest readings: 14 psi
  5. XJ550H
    no you need to check them, compression is not just about the valves.
    compression helps to determine condition of motor, and the direction you would follow in repairs.
    check your valves adjust if needed do compression again .
    I would do full ignition test and charging system tests.
    do all the inspections which is cost free to do
    with that done you can then make the choice to continue and where to spend your money first. Make a plan to follow
    you already know your going to spend money on the carbs at minimum for seals if all your parts are good.
  6. Alex mathieu
    Alex mathieu Member
    griffin ga
    I've already built carbs, synced and all. New coils and stator. Charge system is in spec. Valves are the absolutely only thing that haven't been done.
  7. Alex mathieu
    Alex mathieu Member
    griffin ga
    Thank you both for the information :) guess I'll be checking the valves now.
  8. XJ550H
    first and goal take it in for the score.
    Alex mathieu likes this.
