Adding Aftermarket Tachometer
Discussion in 'XJ Technical Chat' started by Vykn, Aug 31, 2015.
  1. Vykn
    Vykn New Member
    Central-East Florida
    I bought the bike without a cluster, and am wiring an aftermarket tach.
    Has anyone here done it? I'm confused about where I'm supposed to attach it on the coil side due to having two. The connector in the headlight has four terminals.
  2. k-moe
    The grey coil wire is used to feed the tach.
    Vykn likes this.
  3. Myck
    Myck New Member
    Perth
    Hi K-moe
    just hooked my after market tach up
    couldnt get it to work and then just seen this post and hooked the green feed line to the grey and the engine would crank but woudnt fire. disconected the green and she fired straight up.
    any ideas mate?
  4. Myck
    Myck New Member
    Perth
    ok checked the grey wire with the multi AC and that is working great.
    the other 2 wires coming off the tach (not including the normally lighting) are a soild black and a black/yellow stripe
    any idea where i should join these
  5. XJ550H
  6. Myck
    Myck New Member
    Perth
    Hey XJ550H brought the tach off ebay and this didnt have any diagram
    But I found this from another selling with identical tach
    The grey wire was showing the tach reading on the multimeter
    but if I connect straight ignition power to the solid black it will crank over but not fire
    Unsure what to do with the solid black and the black/yellow stripe wires
  7. XJ550H
    geern is negitive
    black is positive
    black yellow is tach siginal wire connect to gray wire (orange on diagram)
    I was unsure of the wiring diagram colors being correct to the bike colors
  8. Myck
    Myck New Member
    Perth
    XJ550H you're a legend
    worked exactly as you said, thanks for that mate :)
    Jeff Nilson likes this.
  9. XJ550H
    ....maybe in my own mind, i'm still in the wax on wax off class here.:cool:
    always happy when i can help
    Stumplifter and Myck like this.
  10. Skratch61
    Skratch61 New Member
    Thunder Bay Canada
    Had same problem and found a youtube video that showed right wiring. Problem is it's out by 1300 rpm.shows 2400 rpm at idle.Know this by hooking up old tach and it shows 1100 rpm. If anyone knows of a fix for that it would be appreciated.
  11. k-moe
    Is there a switch, or a wiring choice, for the number of cylinders?
  12. XJ550H
    got a link to the tack and video?
  13. Laces
    Laces New Member
    Moses Lake, Washington
    I've put a seca 750 into my maxim 650 bike and now am wiring up a tachometer, where would I hook the tach up to if the previous tach was mechanical and the wiring for my bike isn't fit for an electric tach?
  14. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    this could be foolish and embarrassing for me, but I have never dealt with an aftermarket tach on a bike. but aren't these machines wasted spark? each coil drives 2 cylinders, and when cyl 1 fires cyl 2 is also sparking but just has no fuel to ignite? (or however the pairs are wired I forget what cylinders share what coil) so wouldn't it read double the speed, which is basically what scratch is seeing? so how would you account for that? its not 1 pulse per cyl?
    on an older car with tradional distributor and single coil aftermarket tachs have switch for how many cylinders, but thats is still dealing with a single pulse from a single coil so that makes sense to me. I cant figure out wasted spark.
  15. k-moe
    You have two choices:
    Wire it for an electronic tach (easy, and has been done by many).
    Have the head machined to accept a mechanical tach drive from the 650 ( not so easy, costly)
  16. k-moe
    You are correct, which is why most aftermarket tacs of any decent quality are switchable/ wire able for wasted spark applications ( very common in motorcycles).
  17. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    my acewell has a .5 setting for number of cylinders, and works just fine.
    stu
  18. Laces
    Laces New Member
    I've decided to go with the new Tach. Where on my bike would I hook up the new tach wire?
  19. k-moe
    The grey wire on the right hand ignition coil.
  20. Laces
    Laces New Member
    Thank you!
  21. Jeff Nilson
    Jeff Nilson New Member
    Oropi , Taurnga New Zealand
    Hi Myck,
    I have just bought an aftermarket Tacho to put on my XJ650 , sounds like similar wiring to the one you did, see attached
    I havent tryed to install yet ... trying to make the mosy of summer in NZ before it gets cold
    Did your one show the correct revs?
    cheers
    Jeff
