Wanted 80 to 83 seca fuel tank
Discussion in 'For Sale, Trade/Swap, Wanted' started by techypm, Feb 25, 2015.
  1. techypm
    techypm New Member
    United States
    Im working on a 1980 xj650 maxim café racer. Last part needed is a fuel tank. thanks for your time.
    if you have one just post the price and a picture.
  2. hogfiddles
    So..... Are you looking for a tank for:
    750 Seca. (Plenty around)
    650 Seca non turbo (rare)
    650 Seca turbo ( unlikely )
    550 Seca (fits with modification)
    400 Seca ( probably to small)
    Your title just says 80-83 Seca..... All of the above are in that timespan----
  3. techypm
    techypm New Member
    United States
    non turbo 650 or a 750 should work.
  4. techypm
    techypm New Member
    United States
    Atm I'm looking for a tank that has the leg indents and i know a lot of the seca tanks fits the maxim frame.
  5. hogfiddles
    From a few of the many previous discussions here:
    Just for giggles, I did swap some things around to see how things fit:
    1 900rk Tank- does NOT mount onto the xj650 maxim, xj750 maxim, OR xj750 seca frame. The upper mount for the frame reflector contacts the seam edge of the 900 tank before the tank can slide onto the rubber mounts. If the reflector mounts were cut off, the tank would slide onto the rubber mounts, BUT the tail of the tank would still be about an inch too far back and will still not allow the tank to be bolted down.
    2.750 Maxim tank - as we all know, the 750 maxim tank is a direct bolt-on swap for the 650 maxim tank. The 750 maxim tank WILL also bolt directly onto the 750 seca frame without any modification to the tank of the frame.
    The seca seat will still work on the frame, but there is about a 1" or so gap between the seat and the 750 maxim tank.
    The seca side covers will not mount onto the frame as the tail end of the maxim tank aims down at the back and interferes with the sidecover top-front edge.
    3. 750 seca tank - WILL physically bolt directly onto the 650 and 750 Maxim frames.
    The Maxim seat front edges need to be modified to fit the extra length and steeper angle at the rear of the 750 seca tank.
    I did not have time to check on sidecover fit. However, due to the upsweep at the rear of the seca tank, the maxim side cover upper front point should still be ok and not interfere.
    Hope that helps some............
    Dave Fox
    Regarding 650 Seca / 650 maxim
    Frames are different, I haven't done a seat-swap comparo, but I have done tank-swap comparo which is here in another forum......
    That all said, if I get the time in the next few days, I'll try to do that for you.
    In the meantime, a quick solution would be to pull the covers and foam, and the do a Seatpan swap..... The seat mounting is different
    The 650 rj tank will fit the maxim frame, but you should use the 650rj triple clamps to allow clearance at the front if the tank.... Otherwise you'll run the fork tubes up against the tank on tight turns
    Dave fox
    Regarding 550 Seca / 650 Seca non-turbo
    http://xjbikes.com/forums/index.php...rily-550-seca-and-650-seca.47996/#post-426801
    techypm and ecologito like this.
  6. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    Thank you for all that info Dave. it is very helpful.
  7. radbadbrad1987
    radbadbrad1987 New Member
    meridian ms
    parting seca 650 turbo
  8. hogfiddles
    650 turbo tank is completely different.
  9. Toomanybikes
    Tsawwassen bc
    Have an 81 750 seca tank not dented but black paint scuffed up $40 US plus shipping includes tap and fuel sender
    Can send from Point Roberts WA
  10. Team43
    Team43 New Member
    TX
    Not to hijack his thread but do you have pictures of the 750 tank in case he doesnt want it? Looking for a tank for a 80 XJ650 Maxim so it looks like that will fit mine.
  11. EvenStephens
    EvenStephens New Member
    North Carolina
    will a 750 seca tank fit on a 550 maxim???
  12. hogfiddles
    Search for my tank swap writeups
  13. Busted Knuckles
    Busted Knuckles Member
    North
    I have a 82 XJ650 Seca tank I can part with. Few scuffs but no dents. Unsure of how the shipping will work. Isn't that like, hazmat stuff?
  14. xjazz
    xjazz Member
    Pennsylvania USA
    I think it's OK to ship a tank as long as it's been thoroughly cleaned out .
    Knuckles, how much do you want for the 650 Seca tank?
    We're talking non-turbo, right?
    Can you send me a photo?
    I'm in south central PA
    tHANKS.
  15. Busted Knuckles
    North
    Ehhhhhh, I'll have to thoroughly go through it. It still has ~a gallon of 93 in it. Its scuffed a little by where the seat rested against it. No dents though. Technically you can't ship a used tank. But they don't have to know. I'll flush it out with lots of water. Throw some air freshners or something in the box, haha.
    It also has the locking cap, but I only have one key. I'll keep it unlocked if I ship it.
    It is a non turbo bike.
    I'll take a few pics.
    I'll get back to you on price; just not sure what these go for.
  16. Busted Knuckles
    North
    @xjazz , your inbox is still full.
