Torque spec for Caliper slide bolt.....
Discussion in 'XJ Technical Chat' started by Blackfnttruck, Jan 8, 2016.
  1. Blackfnttruck
    Blackfnttruck Member
    Harrisburg Pa
    It is not clear, at least to me, in the manual I have. Does someone know, of course you do, the torque spec for the caliper slide bolt? The one that holds the support bracket and caliper body together, on an XJ650RJ.
    Thanks.
  2. k-moe
    Tight, but no too tight. Use blue threadlocking compound on clean threads and tighten it until it is snug. FWIW there is a general torque table for fasteners in the front of most service manuals. Shop practice is to use those guidelines unless a specific torque value is given for a particular fastener.
  3. Blackfnttruck
    Harrisburg Pa
    Thanks, I have the Haynes workshop manual, but it doesn't seem to specify that particular one. Appreciate the input.
  4. XJ550H
    this any help?
    or this pivot bolt
  5. k-moe
    None of those. He's asking about the bolt that locates the two halves of the Seca caliper and holds them together.
  6. Blackfnttruck
    Harrisburg Pa
    Correct, I have that same list, but it doesn't seem to be on that list....thanks.
  7. XJ550H
    is this a picture of the caliper & bolt 8
  8. Blackfnttruck
    Harrisburg Pa
    Yes, that is the one I am referring to.
