New and clueless. 83 XJ650 bobber project.
Discussion in 'XJ Technical Chat' started by JJJJJ, Jan 28, 2016.
  1. JJJJJ
    JJJJJ New Member
    CA
    Hello everyone, I am new to the forums and new to motorcycles. I bought a 1983 XJ650 K. It is stripped down pretty bare. I found the minimal wiring diagram and i have it wired up except for the lights. The stater engages and the engine turns. I am trying to find a tank that fits so i can get some fuel to it to see if I can get it running. This brings me to my next problem. The carbs that it came with are not the stock ones. I can't get them to fit into the boots in the intake. I think they had them rigged up with some pvc pipe and plastic tubing. I think the reason being that the stock boots are about a half inch too short. The carbs have a nipple on the bottom of them that rubs the motor underneath the carbs preventing them from pushing all the way into the boots. Any advice about how to address this would be greatly appreciated. I'm sur this is one of many issues i will need help with.
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Pictures?
    The people her can and will be very helpful with getting your bike running.
    Coty likes this.
  3. XJ550H
  4. XJ550H
    you can use an lawn mower tank just to start it.
    650K so it is a Maxim?
  5. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Good luck. Not to be discouraging but you will be riding a hell of a lot sooner, and probably a lot cheaper, if you find a set of the correct carbs. If you need funds, try to determine exactly what carbs you have and sell them, someone out there needs the set you have. But honestly if you are new to this, I wouldn't dream of starting with the wrong carbs and trying to make them work. Maybe if you already had a couple of running bikes and just wanted this to be a long term project, but as I said above you'll be on the road sooner if you put the bike back as close as possible to stock/factory.
    Ray and k-moe like this.
  6. k-moe
    Post up pics of the carbs and of the intake side of the engine. It's possible that you have the correct carbs, but that the intake boots were put back on in the wrong locations.
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    And possibly the wrong boots for his model modified to fit.
    Gary H.
  8. JJJJJ
    JJJJJ New Member
    CA
    Here's a pic of the carbs as I was trying to put them on. I'm pretty sure they are the right boots just the wrong carb. I couldn't find a model number on them. I'll snap some pics of them tonight. This is gonna be a long term project no doubt. I was thinking of getting some universal fit boots that are longer than the stock ones. Will that work or is it completely a waste of time? Thanks for the advice
  9. JJJJJ
    JJJJJ New Member
    CA
    Here's a pic of the bike, it's pretty much just a frame and engine. I only paid 150 bucks for it though.
  10. k-moe
    Ummm ya. Not the correct carbs at all.
    FInd out what they are, sell them, and use the proceeds to pay for the correct set.
  11. Stumplifter
    near Irma, WI
    Another one for "Guess what the PO did to my bike?"
    Those are rather unique looking carbs (at least to me), do as K-moe suggested, they may be greatly sought after by someone!
  12. JJJJJ
    JJJJJ New Member
    CA
    Here's a pic from the side of the carb, there's really nothing else on it
  13. Stumplifter
    near Irma, WI
    http://www.keihincarbs.com/home.html
    A quick search reveals that this are from and atv and may be worth about $30 each.
    But do your research, measure the throat to see what size they are and what application it is truly used on, then hit the Artic Cat (or whatever) forums and see what you can get for them.
    Alan63 likes this.
  14. Steve M.
    Steve M. Member
    Bedford co va
    Yes take them off they're ugly!!
  15. XJ550H
    Ray likes this.
  16. jayrodoh
    jayrodoh YimYam
    Cleveland
    They kinda look like the carbs from an early 70'S Honda CB. 750 maybe?
    DrewUth and Ray like this.
  17. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    JJJJJ and Ray like this.
  18. JJJJJ
    JJJJJ New Member
    CA
    That looks like them. You guys are great! I tried to ID them by measuring but they don't match anything on the site. Will they work on an xj650? I had some spacers made so I was able to mount them. Here's a pic
  19. rocs82650
    Middle Tennessee
    Idk...you'd have to know exactly what they are from, clean them up and make sure they can be installed with the airbox and boots without leaks then see if you can dial them in. Imo...
    Gary H.
    Ray likes this.
  20. quebecois59
    Kehin carbs ! They were common on vintage Hondas.
  21. jayrodoh
    jayrodoh YimYam
    Cleveland
    Given enough time and money, you could make any carbs work.
    Better yet, find the set that yamaha spec'd out originally and ignore the hassles. Sell those to the guy with a Honda that needs carbs.
  22. JJJJJ
    JJJJJ New Member
    CA
    Sorry I've been inactive for a while, but does anyone know what years carbs are interchangeable for these bikes? I just got a fuel tank and now I'm looking for carbs. I've found 82 and 81 carbs but don't know if they will work. I appreciate any advice given.
  23. XJ550H
    83 650 is it assembly wise
    you have HS-32 carbs it would just be rejetting to suit your bike
    for jet sizes
    http://xjbikes.wikidot.com/carb-specs
    may be 82 will direct swap with jets
    Years & Models: 1982-3 XJ650 Maxim USA models
    Carb Manufacturer: Hitachi
    Carb Series: HSC32
    Carb Model ID: 5N800
    Main FUEL Jet Size: #110
    Pilot FUEL Jet Size: #40
    Main AIR Jet Size: #50
    Pilot AIR Jet Size: #205
    AIR COMPENSATOR Jet Size: #36
    Starter FUEL Jet Size: #40 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-10
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    Idle RPM's: 1,050 rpms
    wrong jets in 80-81
    Years & Models: 1980-1 XJ650 Maxim, Midnight Maxim, and XJ650RJ and RJC Seca Canadian models
    Carb Series: HSC32
    Carb Model ID: 4H800
    Pilot AIR Jet Size: #195
    Main jet NEEDLE ID: #Y-12
  24. k-moe
    XJ750 carbs are the same except for jetting.
