1981 Yamaha xj650 wiring
Discussion in 'XJ Technical Chat' started by Alex kaiser, Oct 1, 2015.
Tags:
  1. Alex kaiser
    Alex kaiser New Member
    Whitewater wi
    Hello there, I have a Yamaha xj650. That is bobbed out that I worked on and fixed mechanical issues on. My current problem is the wiring. The wiring on it is sloppy and a total hack job. And while I was riding it ended up dieng on me. Nothing works now and the engine doesn't crank over. I just purchased a new wiring harness off eBay. I can do mechanical things on the bike, but electrical I'm not too good at. I'm just wondering how everything will fit together and how to rewire it correctly. I can post pictures upon request.
    do you want to do minimial wiring? there are posts on it with diagrams
  3. XJ550H
  4. XJ550H
    did you upgrade your old glass fuses?
    also you may want to check your clutch safety switch,side stand safety switch neutral safety switch.
    all can be bypassed to test them
    when you remove the old harness take photos of routing and wire ties all connectors
    thread on clutch safety switch
    http://www.xjbikes.com/forums/threa...tch-switch-by-just-looking.30354/#post-261972
    if you do not have a meter get one you will need it
  5. XJ550H
    when you say nothing works do you mean that?
    turn key on do you hear relays click? does your tail light light up?
    in neutral does your neutral light come on?
    no horn, no turn siginals?
    you need to test your battery voltage.
    you need to test voltage at your fuses with a meter both sides of the fuses and on the clip crimp not the fuse or clips.
  6. Alex kaiser
    Whitewater wi
    basically the engine doesnt crank, no headlights, no taillights. nothing lights up. today i stripped all the old wiring off the bike. And i was going to proceed to put the new harness in, but not everything matches up quite right. I have alot of connections that dont have a home. and yes i want the minimal wiring
  7. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    Did you check for a good ground , or main power cables to begin.. I know it's kinda late for me to be asking now, as a rule check out the simplest things first.
  8. XJ550H
  9. Alex kaiser
    Whitewater wi
    the grounds i am going to look over today, and all of the main wires have are plugged in with some exceptions that do not match up.
  10. XJ550H
    get a piece of ply wood and lay out your old harness on it use nails and wire ties to hold it in place.
    mark all your connectors and put markings on the board for each one and wire runs too .
    diagram on board where the go to and from.
    then you open it up and start stripping away the wires you do not need.
    or you can use the layout for a pattern do it twice on the board one for old harness second for a pattern to build new harness
    buy some wire and build a custom one adding some extra wire lenght for crimping mistakes .
    you may also be able to eliminate or relocate some of the
    connectors
  11. willmarmnxj650
    willmarmnxj650 Member
    Willmar mn
    Does anybody have pictures of there minimal wiring?
  12. XJ550H
    yes
    willmarmnxj650 likes this.
  13. willmarmnxj650
    Willmar mn
  14. willmarmnxj650
    Willmar mn
    Ive seen this many times but does anybody like have pics of there actual minimal wiring harnesses they made themselves on and off the bike
  15. k-moe
    It's not going to look much different from the factory harness. It just has fewer wires.
    Is there something specific that you're looking for about the layout or routing?
  16. XJ550H
  17. Samantha Taylor
    Samantha Taylor New Member
    Washington
  18. 82650secamuffins
    82650secamuffins Member
    san francisco california
    how about simple wiring a blade fuse to a toggle switch to headlamp from battery positive then ground?
  19. DoubleTigerLefty
    DoubleTigerLefty Member
    coquitlam
    Get a manual!
    Hayes makes a great one, which includes a wiring diagram and loads of troubleshooting tips and tricks. With enough patience you can learn anything.
    I had an awfully old and chopped up wiring harness from the previous owner, and I basically redid the entire thing. I took my time to map out on the bike, wire by wire, where I wanted to run them. I'll be locating all the gear under the seat, mounting the rectifier, fuses on a pan I'll beat out of some sheet metal. I'll wrap the cables together, and I'll have a custom harness simply by following the map of the wiring diagram in the Hayes manual.
    Persevere with patience! Take care to make connections tight and sealed, crimp with enough bare copper, and leave yourself a little slack. You'll have a sweet, reliable ride when you're done.
  20. DoubleTigerLefty
    coquitlam
    There's also a post about testing your ignition circuit out there, but I'm leaving my toilet now and don't have time to find it for you.
  21. 82650secamuffins
    fixed used toggle ,two wires one through positive other on neg..on.off.on switch..works fine just double check whether off or on is essential..
  22. k-moe
    Are you talking about the headlight circuit still? Running that much current directly through a switch will lead to the switch failing fairily soon. Headlights should always be wired with a relay.
  23. 82650secamuffins
    ...april 2 n switch still fine...
  24. willmarmnxj650
    Willmar mn
    My progress
  25. Bburgess
    Bburgess New Member
    Missouri
    I'm confused as to how the kill switch kiss the power? Shouldn't it be between the power to the coils?
  26. XJ550H
    ignition fuse supplies voltage to kill/run switch then it goes to tci coil and solinoid
    in the color min wiring diagram that is how the kill switch is installed . in the bw drawing there is no kil switch just the key which supplies power to fuses
  27. Bburgess
    Bburgess New Member
    Missouri
    I ended up installing it in the power switch to the coils, it works, now my issue is, even if battery gets disconnected it still runs.... What have I done wrong
  28. XJ550H
    power switch is ignition switch with key? (just to be clear)
    which wire ? not the red one it always has power brown wire (Br) or blue wire (L)
    this drawing?
    min ig.JPG R(red) wire always hot from main fuse, when key is turned on it supplies voltage to Br(own wire to the fuses, and b(L)ue wire for tail lights
    do you mean literally "even if battery gets disconnected" ? if you hooked to the red wire you are running off the alternator. never disconnect battery
    kill switch wants to be directly after fuse before tci ,coils ,and solinoid. if it is after tci, switch could still arc and keep bike running.
  29. Bburgess
    Bburgess New Member
    Missouri
    Yes keyed ignition, should I swap red and brown wire off the ignition so it doesn't have constant power?
  30. XJ550H
    red wire is always hot from main fuse, and sends power to brown and blue wire nothing should be connected to the red wire but main fuse
    red is input brown and blue are output
  31. Bburgess
    Bburgess New Member
    Missouri
    OK, so as I look at it, I have red running to igniter, pig tailed to started solenoid. Is that correct?
  32. XJ550H
    from brown wire on key switch connect red/white wire to fuse then red white wire to ignihtor, solinoid and both coils just like drawing
  33. Bburgess
    Bburgess New Member
    Missouri
    OK everything is rewired to the brown. Now shuts off when key is turned off. Positive piece of metal that comes from solenoid that connects to the battery is broke so I stuck it behind the positive terminal. Before I rewired it, if it popped off the terminal it would kill the kill the bike. Now it will still run. How do I fix this? Is it running off the alternator? If so what is wrong
  34. Bburgess
    Bburgess New Member
    Missouri
    Followed wiring diagram but bike still running off alternator and not the battery, what am I missing?
