Charging Problems....
Discussion in 'XJ Technical Chat' started by Marc, Feb 7, 2016.
  1. Marc
    Marc New Member
    Jacksonville Florida
    So I have a 1983 XJ750 that will not charge no matter what I throw at it. I have replaced every component save two, the carbon brushes (that are clean and in spec.) and the alternating rotor. My rotor measures three ohms which I understand is below spec. but damn I am getting Nothing at the battery. Does anyone have a source for a NEW alternating rotor I can buy and put this bike back on the road? My e-mail is batardpaiens@gmail.com and my cell number is 1-904-534-7220.
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Have you checked all the ground connections? Delete your personal info (trolls roam here) and start a conversation with Chacal (Len); he's our parts guru.
    Gary H.
  3. XJ550H
    did you use an eraser to clean the surfaces where the brushes make contact
    there are 2 parts to the alternator
    rotor and stator
    also you will need to test the voltage regulator and clean all connections
    download this set of manuals
    haynes 650-750 free down load
    http://www.manualslib.com/manual/837861/Yamaha-Xj750.html
  4. XJ550H
    page216 of haynes
  5. SQLGuy
    SQLGuy Well-Known Member
    Check the connections where the alternator plugs into the regulator/rectifier (three white wires, plus a black, a brown, a green, and a red) under the left side cover. These connections tend to oxidize, heat up, and melt the connector (as well as losing contact). Clean or replace them if they show signs of oxidation or melting. This is a common cause of charging problems in these bikes.
  6. Marc
    Marc New Member
    Thanks for the good advice guys! I have a simplified the wiring harness and the grounds are solid. I am just not getting any voltage from the three white wires. I believe I simply need a good rotor as mine is below spec. I will hit up Chacal and see if I can get a good one.
  7. rocs82650
    Middle Tennessee
    Did you three phase test it? Just asking.
    Gary H.
  8. SQLGuy
    You did check on AC when checking for voltage on those wires, right?
  9. Polock
    rotor, stator, one spins one don't. can something really go wrong with the rotor?
  10. k-moe
    The laquer on the rotor coils can fail from heat or age and cause a short, or cause the wire to corrode through.
  11. Marc
    Marc New Member
    yes i did check for AC voltage
  12. toolman
    toolman Member
    NS Canada
    I always like to cut that connector off.
    This is worth doing even if your charging system is working. (in my opinion, some may not agree)
    First, test the voltage at the battery when the bike is running.
    Second, cut off both ends of the connector.
    Third, splice and solder the wires together then heat shrink or tape the wires. (make certain you keep each wire separate from the others)
    Fourth, recheck battery voltage with the motor running.
    I bet you'll see an improvement.
    Toolman
  13. SQLGuy
    If there's no AC voltage between any two of the three white wires, the problem pretty much has to be in the field coil. If the field coil (Brown to Green) measures in-spec from the connector, and is getting 12V or so when running, then something is missing in your test process. If it measures in-spec, but is not getting much (DC) voltage between Green and Brown, then you probably have a bad regulator.
  14. Rooster53
    North, FL
    Any luck on this? The 3 ohms on the field coil does seem like the problem so either a good used one or rebuilt one would be good advice.
    I am local (Jacksonville) and have a little bit of electrical experience if you get stuck. I also have the tools for removing the field coil and a spare used field coil that you would be welcomed to borrow if needed.
    If the measurements of 3 ohms are accurate on the field coil, I would suggest not hooking another regulator up to it until the field coil is replaced. I have no idea what the maximum current rating is on the regulator, but it might be possible to damage the regulator with low ohms on the field coil before blowing the ignition fuse.
  15. bunglejyme
    bunglejyme Member
    New Jersey
    Can't hurt any doing this.
  16. k-moe
    Eliminating the connector does make some other repairs a bit more difficult. I'd reccomend replacing it with a new, waterproof connector to eliminate the oxidation buildup that leads to the wires burning.
    Marc likes this.
  17. toolman
    toolman Member
    NS Canada
    anything is better than stock
