my new bike... where do I begin?
Discussion in 'XJ Technical Chat' started by caliXJ_Bobber, Apr 1, 2016.
  1. caliXJ_Bobber
    caliXJ_Bobber Member
    california
    Picked her up for $350.00
  2. caliXJ_Bobber
    california
    The valve cover is off, needs wiring done, gas tanks are rusted inside... Came with a sportster style peanut tank. Has a complete gasket set which I plan to install.. Drive shaft is disconnected also... And rear brake is "laminated" wtf ever that means... But I'm sure that I will need to put some work in on that too. I got a lot on my plate and I'm extremely eager to get started.
  3. k-moe
  4. XJ550H
  5. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1 what k-moe and 550 said. Get a manual, assemble the drive shaft, valve cover w/gasket and remove the rear wheel. Source a good used harness from e-bay or start a conversation with Chacal.
    Gary H.
  6. XJ550H
  7. a100man
    a100man Well-Known Member
    Bedford, UK
    Still, nice orange/gold starter motor...
    .. but appears to be missing an important stoppy device front left.
    caliXJ_Bobber likes this.
  8. caliXJ_Bobber
    california
    yeah, its definitely going to be a project
    I cant wait to get started on her. Any one know of a pdf manual i can down load and print out?
  9. saftie
    New York, NY
    Never heard that one before :)
  10. XJ550H
    link posted in my post above has free download of manual for 650/750 haynes manual
    here it is again
    click it
    XJ750 manuals
    all the titles i posted above are links, that wikk do you well to read
  11. caliXJ_Bobber
    california
    Thank you!!!! That is definitely going to come in handy. Will be printing it out when I get to a comp... I'm on my phone at work right now.
  12. k-moe
    Oh, I hadn't looked at the photos. Become very familliar with what all the parts look like, and where they go. Also become familliar with testing and inspection procedures for each assembly. I think you will be doing a full teardown and inspection. That U-joint was unbolted from the output shaft for a reason. The mystery is; what reason? And since it's unbolted you're most of the way to pulling the swingarm out to inspect and replace/repack the bearings. Also the misalignment there makes me think that the rear engine mounting bolts hae been removed. Maybe just to pull the foot pegs, but maybe to pull the engine.
    Slow, methodical, patience. Don't try to force a end-date for this to be ready by.
  13. rocs82650
    Middle Tennessee
    He intends to bob it. Imo he needs to get it together enough to do the compression test so he'll know the mill is viable and he can go forward with the project.
    Gary H.
  14. 79xs
    79xs Member
    A new project is always fun. I always think of this when I bring something new (old) home.
    caliXJ_Bobber and jmilliken like this.
  15. caliXJ_Bobber
    california
    ok. I got the bottom part of the factory tank off.. I'm going to look in to mating it with a harley sportster peanut tank - I know I'm going to lose a significant amount of fuel volume, but I love the small tank look.
  16. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Ecto 1 needs suspension work AND shocks? I wonder if they can do both at the same time?
  17. caliXJ_Bobber
    california
    I ordered a Haynes manual for her on Friday. Should be here on Monday. Once it gets here, I'm going to start working on getting her back together and running.
  18. rocs82650
    Middle Tennessee
    If you have the engine mounting hardware and output to driveshaft bolts temporarily assemble the engine and driveshaft so you can try to manually turn the motor over to get the valves in spec. Have you sourced a good used wiring harness?
    Gary H.
  19. caliXJ_Bobber
    california
    Not yet, but I know I'm going to need one. Got any leads?
  20. caliXJ_Bobber
    california
    I will start figuring all the timing stuff out too when the book comes in. I'm going to have to do break jobs too.
  21. rocs82650
    Middle Tennessee
    There's one on e-bay under "xj650 maxim wiring loom" for $38.XX. It appears to be in useable condition.
    Gary H.
