Leaky neutral switch
Discussion in 'XJ Technical Chat' started by wkxj, Apr 23, 2016.
  1. wkxj
    wkxj Member
    nm
    The 550 is leaking oil from it looks like behind the neutral switch.
    I was thinking about making a gasket if I need to.
    I haven't had it apart so I have no idea what I'm up against at this point.
    How much oil leaks when you pull the white cover?
    Any thoughts or experience would be appreciated.
  2. k-moe
    Looks to me more like it's coming from the shift-shaft seal.
  3. wkxj
    wkxj Member
    nm
    It could be.
    I had one leak on a GL500 once.
    It wouldn't hurt to go ahead and replace it if I can find one.
    So any idea what's behind the neutral switch cover?
  4. k-moe
    The neutral switch. Oil. The shift drum.
  5. wkxj
    wkxj Member
    nm
    Okay it looks like there's a O ring behind it.
    In case anyone needs to know. It looks like you can get them and the shift shaft seal
  6. XJ550H
    Neutral Switch Assy
    1L9-82540-00-00 $18.8222 O-Ring 93210-29196-00 $3.64
    chacal does sell all the seals you need i got the shifter seal and sprocket seal from him.
  7. wkxj
    wkxj Member
    nm
    Thanks!
