1982 XJ650
Discussion in 'XJ Modifications' started by BJ Ramirez, Jan 22, 2016.
  1. BJ Ramirez
    BJ Ramirez New Member
    Washington State
    Bought this bike from my cousin for 100 american big ones! What a steal!! There was no key, but was able to bypass ignition switch. Fuel tank was empty and had a small amount of surface rust. I was able to clean it out with apple cider vinegar and distilled water. Put some fuel in and got it to start right up... on 2 cylinders though. I will be pulling the carburetors out this weekend. More to come!
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Welcome aboard.
    Gary H.
  3. XJ550H
    theres a lock smith on ebay that can cut keys from the key number that is on the bottom of the ignition switch $30 you get 2 keys
    http://www.ebay.com/itm/39022795024...em=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr
    check the coils and plug caps as well as the pickup coils that could be why you only get 2 cylinders running.
    you can down load a repair manual free here
    http://www.manualslib.com/manual/837861/Yamaha-Xj750.html
    some good reading here with lots of specs
    The Information Overload Hour
    and carb cleaning info
    IN THE CHURCH OF CLEAN
    Something New, Something Naked
    THE SECRET LIFE OF CARBURETORS
  4. BJ Ramirez
    Washington State
    Thanks for the advice guys.
    Update on the bike. Checked and confirmed good compression across all 4 cylinders, aswell as good spark.
    Pulled the carbs out and found two of the needles were stuck. When I pulled them apart, the rubber tip on both needles ripped off. I ended up ordering rebuild kit for all four. Now I wait for parts.
  5. BJ Ramirez
    Washington State
    Started stripping the bike since I'm waiting on parts. I know you guys don't like cutting these up, but I had to. Went with a none traditional frame loop. I used a set of handlebars I had laying around to get the shape I wanted. My welding skills are ok, but my grinding skills are even better!
  6. Busted Knuckles
    Busted Knuckles Member
    North
    Let me know if there are any parts you need. I've got an 82 XJ650 Seca that has been completely disassembled. All the parts are on a pallet in the garage.
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
    LOL! I'm in that club as well.
    Ray likes this.
  8. k-moe
    Did you sleeve the welds? I really hope that you did.
  9. BJ Ramirez
    Washington State
    The bar's are a 7/8" O.D. and had to be twisted into the frame. I was able to get them in about an inch and then put the weld down.
  10. BJ Ramirez
    Washington State
    Switch "Dad" with "Coworker" haha
  11. k-moe
    Good deal. From the other angle they looked like butt welds on the same size tube.
  12. BJ Ramirez
    Washington State
    Picked up a couple of XJ750's. One of them is complete but missing the key. The other is a parts bike.
    I decided to use the seca tank on my 650. Went ahead and trimmed up the front fender as well.
  13. k-moe
    I need room for parts bikes......and money for parts bikes :(
    BJ Ramirez likes this.
  14. BJ Ramirez
    Washington State
    Lucky for me, I have an awesome boss who let's me store them at the shop
  15. Busted Knuckles
    North
    Then you have plenty of room for all the XJ650R Seca parts I'm trying to unload! :D
  16. BJ Ramirez
    Washington State
    I was initially going for a cafe racer feel, but decided to flip the bars and go the scrambler route. I'm working on fabricating a face plate to mount the light and hide wiring.
  17. BJ Ramirez
    Washington State
    Haha. Email me what you got. I may need some parts!
    Jramirezzj21@yahoo.com
  18. XJ550H
    the key code is on the bottom if the ignition switch I posted an ebay lock smith in my first post. great service on getting me 2 keys for 30$ key blanks will cost 8 to 15 $ and you would still have to find someone to cut them
  19. BJ Ramirez
    Washington State
    I will have to check that out. The bike is all original and want to keep it that way.
    rocs82650 likes this.
  20. rocs82650
    Middle Tennessee
    @XJ550H: You should ask Snow to sticky that link in the DIY forum.
    Gary H.
  21. BJ Ramirez
    Washington State
    Working on the faceplate. I have a few more things to finish on it, but that should be the overall look. Also want to mount the fender up higher.
    Ignore my poor photo shop skills. Trying to get a better idea of where to mount it.
  22. mpospeschi
    mpospeschi New Member
    wi
    Dear Mr Ramirez,
    Do you own a xj750 or a xj650?
    Because I own a 1981 xj750r seca 750.
    I am in need of a right hand side cover, Can you help me ?
    Thankyou, Matt
  23. BJ Ramirez
    Washington State
    Rebuilding some carbs!
  24. k-moe
    Lay a white tea towel down on that bench before you start losing small, but expensive, parts.
    XJ550H likes this.
  25. hogfiddles
    And use an egg carton, or a muti-compartment tray.......
    XJ550H likes this.
  26. rocs82650
    Middle Tennessee
    Exactly.
    Gary H.
