Chain rubbing center stand
Discussion in 'XJ Technical Chat' started by wkxj, May 2, 2016.
  1. wkxj
    wkxj Member
    nm
    Okay, I got the sprockets cleaned up and put on a new chain.
    I adjusted it with about 35mm of deflection but the
    chain is touching the center stand.
    Is the 550 supposed to have a chain guide?
    The center stand doesn't look bent.
    Any ideas?
    are you using an aftermarket mac 4 to 1 exhaust? if so there is an L bracket that mounts on the left side footrest bracket that holds down the center stand to keep it from hitting chain
    on stock exhaust there is a bumper that goes on muffler part 24
  3. wkxj
    wkxj Member
    nm
    The bike only has the H box on it now.
    That's how I got it.
  4. XJ550H
    4to1 006.JPG 4to1 007.JPG 4to1 012.JPG 4to1 016.JPG 4to1 017.JPG you can bolt an l bracket to the exhaust mounting hole in the foot peg bracket it rests on the center stand and holds it down from hitting chain I will look for my photo of it
    yellow tape is for visability
  5. XJ550H
    I removed it and reversed it so foot faces out for better results it is shown backwards in photo
    nice photo of your old pick up plate
  6. wkxj
    wkxj Member
    nm
    That's a good idea.
    Thanks!
    Haha yea it has a 1/4 inch of rust caked on it
  7. XJ550H
    the bracket is part of the mac 4 to 1 kit did not know what it was for as there are no instructions sent with kit.
    some members have put emgo shorty mufflers on the 550 box with nice results
  8. wkxj
    wkxj Member
    nm
    I like those shorty mufflers. I've used them on a couple of bikes in the past.
    Once on a 74 TX500 and more recently on a GL500.
    On the GL I used some angled adapters so the mufflers where at the same angle as the frame.
    Turned out pretty cool.
    The cool thing is I still have the chrome hangers that came with em.
    I might be able to make something to hold the center stand down with them.
    If I can find them that is
