550 Seca Fork HELP
Discussion in 'XJ Technical Chat' started by jmcgrew, May 21, 2016.
Tags:
  1. jmcgrew
    jmcgrew Member
    Salt Lake City
    I'm trying to replace the seals on my fork and I can't get the upper tubes out of the fork(sliders.) I loosened up the 8mm bolt on the bottom, however I could never get them removed. the upper tubes won't come out.
    What am I missing? HELP
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
  3. k-moe
    Circlip up top under the dust covers. Remove it. The dust covers pop off with a screwdriver (there is a slot in the fork for that).
  4. jmcgrew
    jmcgrew Member
    Salt Lake City
    Ok so I did this however they are still not coming out. I shined a light down the tube and spun the lower bolt. The damper rod just spins as I turn the bolt. My guess is that this isn't supposed to happen.
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    Not done this (yet) but I have read that a broom handle stuffed hard down th tube might prevent spinning rod or refit the spring an cap and undo bolt first..
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    What bike? My 650 I had to use an inverted spark plug socket and a long extension to hold the damper while I took the bolt out.
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
    Just saw that your subject included the bike.....it's early :confused:
  8. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    I also used a broom handle. worked like a charm.
  9. tabaka45
    Brunswick, Georgia
  10. jmcgrew
    jmcgrew Member
    Salt Lake City
    Ok... so I go the fork apart and back together. I put 230cc in each leg of 10wt oil. Installed the fork back on the bike and have been working on rewiring it.
    I was moving it bike and noticed the fork felt really soft. Just moving the bike the fork compressed 1/2" to 1". I can compress the fork quite easily. I pretty positive this shouldn't happen. Did I miss something? Wrong amount of oil?
    Please help.
  11. XJ550H
    oil is correct when you sit on the bike you are going to compress25%. movement is expected when moving bike.
    pump them up and down ,any oil coming out?
    did you get seals for seca? maxim seals are different size
    did you replace the o rings at the plugs?
  12. jmcgrew
    jmcgrew Member
    Salt Lake City
    There isn't any oil coming out. I did get Seca seals, the 1st ones I purchased were the wrong size.
    I didn't replace the plug o-rings, would this make a difference?
  13. XJ550H
    when you push down and hold forks do you hear air leaking out?
    it is just a good pratice to replace o rings
    from chacal our supporting vendor
    HCP20699 Aftermarket inner fork tube CAP BOLT O-RING, fits either side. Used on all XJ550 models, all XJ650 Euro models, XJ650 Maxim and Midnight Maxim, and 1982 XJ650RJ Seca models. Each:
    $ 3.95
    qty needed 2
  14. XJ550H
    the oil helps dampen the rebound did you notice the holes in the spindel? a few tiny ones and some larger ones.
    upper fork tube goes down and compresses oil, forces oil up then sucks back down as it returns to position.
    thickness of oil is what slows down the bounce.
    the spring is the main part of the system
    I do not think you have a problem unless oil starts leaking out the top of the tube under the cap or at the seals
  15. jmcgrew
    jmcgrew Member
    Salt Lake City
    @XJ550H.. thank you for the help.
