bike wont start getting spark and fuel
Discussion in 'XJ Technical Chat' started by aries101, May 8, 2016.
  1. k-moe
    Yes.
    All speculation aside, nothing will be known until the head comes off. At that point the truth will be revealed. Remember, that PO guy has been known to do some really messed up things. Given what I've seen and been shown; I would not be surprised if someone tried to JB-weld a valve stem back together just to get a bike sold.
  2. aries101
    aries101 Member
    idaho
    Anyone know whats the best way to get/pry the head up without causing damage? Rubber mallet isnt doing the trick...
  3. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    It will...keep tapping being careful around the fins. Feeling strong? Tug upward on either side (left and right) from time to time as you tap on it.
    Gary H.
  4. k-moe
    Soft (empasis on soft) wood wedge (or plastic wedge), carefully applied at the gasket. Tap, tap, tap, all the way around. Just be sure to use a wedge that is softer than the alloy head.
  5. Mustang
    Mustang Member
    Masonville
    Tap tap tap pull tap tap tap, drink a beer return to tapping
  6. DrewUth
    DrewUth Active Member
    South Jersey
    Always quadruple check for bolts you missed. Has happened to me dozens of times.
  7. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    The ones under the head in the center are hard to see sometimes and get overlooked
  8. aries101
    aries101 Member
    idaho
    Got 4 on back under the intake. 2 from center of exhaust and 12 top rounded bolts. Is that right?
  9. rocs82650
    Middle Tennessee
    Yes. You removed the cams and hung the chain right?
    Gary H.
  10. aries101
    aries101 Member
    idaho
    Yep
  11. aries101
    aries101 Member
    idaho
    Sorry for the lack of updates still having trouble seperating the head
  12. k-moe
    Keep at it. It'll come off. Have you tried using wedges like I mentioned earlier?
  13. aries101
    aries101 Member
    idaho
    Couldnt find any plastic ones at the store so gonna try to make some wood ones
  14. k-moe
    The plastic wedges will be in the plumbing department; for leveling toilets.
  15. Mustang
    Mustang Member
    Masonville
    Been a few days how's progress, I'm sitting here wondering all the time asking my self ''I wonder how aries tear down is going'' for some reason I have a genuine interest in this particular project
  16. XJ550H
    try penetrating oil at all the bolts/studs could be frozen from some corrosion that needs some attention
  17. aries101
    aries101 Member
    idaho
    Still tapping away. Had a couple friends come by and lift while i tapped with hammer. Still not a budge. Gonna try this plastic wedge thing if i can find them. Im starting to think maybe the engine is so scarred up inside it locked the head to the block...
  18. ant797
    ant797 Member
    western australia
    proberly time to way up if its just cheaper and less headache to replace engine i dont know about the usa but here in australia in my local gumtree i can pick up a xj750 engine for $200 negoitable
  19. aries101
    aries101 Member
    idaho
    Success! Well kinda... sawed some wedges out of 2x4 hammered down the seam got it loose. Not really sure what im looking at. It appears as though all of the intake valves have been striking the pistons. I think the #2 was just the first to go.
  20. Mustang
    Mustang Member
    Masonville
    Dang that's a bummer, any chance you can salvage the head and block and rebuild?
  21. k-moe
    Pics would be nice if you have the time.
  22. MN-Maxims
    Saint Paul, MN
    If the valve timing were that far off that bike would barely run if at all. For some reason your timing chain skipped on the intake cam causing the valve timing to be off far enough for the valves to hit the piston tops. Better look at the cam chain and tensioner very close to see why this happened.
  23. aries101
    aries101 Member
    idaho
    I think both are salvageable, there is light scarring on every piston, but nothing looks destroyed. Kinda like someone traced part of the valve head with a knife. (Pics included but hard to see) im going to pull/inspect the block tomorrow. If anyone knows the tell-tale signs of damage i should be looking for in this area that correlate with bent intake valves i could use your advice. I was also wondering the cost and time to do a complete rebuild? It seems a shame to be this deep in an engine and not do everything to keep from doing it again. On the other hand, im poor, dont have a lot of free time to dedicate to it (besides weekends) and every nice day i cant ride my bike, a little bit of my sanity is lost. Estimates?
  24. aries101
    aries101 Member
    idaho
  25. aries101
    aries101 Member
    idaho
  26. aries101
    aries101 Member
    idaho
  27. MN-Maxims
    Saint Paul, MN
    I would leave the bottom end alone for now. Just concentrate on the one pistion where the valve broke. If it only has a few dings in the top it might be ok. If there are some major hits along the edge it may have bent the pistion top enough to pinch the upper ring. In which case you would have to pull the cylinders and replace that one piston and rings on all the rest.
    If you can find some good replacement valves any good machine shop could fix that head right up. They could massage some of the damage out with a die grinder and some polishing wheels. Check with Len on the gaskets needed and maybe he or someone here might have a nice set of used intake valves that would work. The exhaust side looked ok but have the machinist look them over good. They might be salvageable.
