Is my starter bad?
Discussion in 'XJ Technical Chat' started by Evan Hawtrey, Jun 6, 2016.
  1. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Brand new battery....no voltage drop in ground side...7/10 in pos side....but bike turns over very slow.... is starter bad?
  2. Evan Hawtrey
    Evan Hawtrey Member
    Green bay wisconsin
    Ground is pretty solid.....and clean
  3. k-moe
    What does the battery voltage drop to when you press the starter button?
    Rebuilding a 30+ year old starter is never a bad idea.
  4. silverdollar
    silverdollar Member
    Chesapeake, VA
    I remove the battery and starter to get it looked at at Advance Automotive to see if they were bad. Following them testing the starter and battery they were both in good working order but the battery as show in the picture is a piece of shit. I'm going to upgrade to a gel battery with a higher cranking amps.
  5. DrewUth
    DrewUth Active Member
    South Jersey
    I don't see why you think that battery is no good; if it tested OK then there is another problem elsewhere. I run conventional type batteries like that in lots of stuff and never ever wish for a sealed unit. In actuality, I prefer these types as I can monitor and manage the electrolyte level as needed, which isn't an option in sealed or gel-type batteries.
    silverdollar and k-moe like this.
  6. Jetfixer
    It is possible for a starter to spin over freely, if it has no "load" on it . The brushes wear down and need replaced at some point. The overhaul kits are cheap .
  7. silverdollar
    silverdollar Member
    Chesapeake, VA
    I charged the battery at 100 percent and it sat for a week, yesterday it was at zero percent. The battery is showing 12 volts when charged plus it keeps leaking and it is not over filled. I have to charge the battery every time I start the bike.
    Your preference is your preference.
  8. DrewUth
    South Jersey
    Well it sounds like your battery is garbage haha, I was just going by the test that Advanced Auto did that it supposedly passed. If it is draining that fast, it is by all means no good anymore.
  9. silverdollar
    silverdollar Member
    Chesapeake, VA
    I don't want to high jack this thread but that is why i'm upgrading to a gel battery and it has more crank power.
