turn signal eliminator
Discussion in 'XJ Modifications' started by kcoop99, Sep 6, 2007.
  1. kcoop99
    kcoop99 Member
    BFE, Nebraska
    Has anyone eliminated their rear turn signals? I have see where you can incorporate them into your brake light. Any ideas or suggestions!
  2. kcoop99
    kcoop99 Member
    BFE, Nebraska
    Nevermind......there is only one bulb in the brake assembly........my bad!!
  3. Altus
    Altus Active Member
    London, Ontario
    Well - I suppose if it's something you really wanted to do - it wouldn't be too hard to wire up some LED modules inside the brake housing to do turn signal duty.
    Not something I'd do though - I'm a big fan of separate, bright yellow turn signals.
  4. Stinky
    Stinky Member
    Flagstaff, Arizona
    If I can remember correctly, eliminating turn my signals was easy. I had to loosen one nut and then cut a few wires with my dikes. Tada.
  5. Deathmetaldan
    Deathmetaldan Member
    Sunbury PA 17801
    i have bullet style marker lights that i am using.... looks alot less dorky
  6. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    There are LED tail lights on the market that have the signal lights incorporated inside the taillight. Checkout Ebay for LED taillights and you'll see what I mean. There are several styles that will work on just about any bike. >PD<
  7. Ease
    Ease Member
    NL, Canada
    Yu could check out some truck lights - I know they even have a light at u-haul that is about the same size as the stock taillight on my seca. You could replace the bulbs with led's and wire em up as blinkers... Might require a kit to make them work as blinkers and taillight.
  8. RickCoMatic
    I want a XJ-Bikes.com Electronic Genus to lay-out plans for a D-I-Y Brake Light Modulator with both Turn Signals Flashings.
    When I hit my rear brake ... I'd like all my rear lights to Flash 3 Times and then my Brake Light come-on with an additional Bulb I'll mount inside there for increased brightness.
    I can solder ... and follow a set of plans.
  9. WarDog12
    WarDog12 Member
    Detroit, MI
    MiCarl bought an IC that will flash the brake light thrice, then hold it steady... What you propose does sound interesting. I'll see what I can come up with, it's been a while since I dabbled in electronics
  10. Polock
    lights
    just above the center of the page they say something about flash then steady
  11. nimitz
    nimitz Member
    McHenry, IL, US
    This is actually one of my winter project plans. I'm going to remove the rear fender and tail-light and install one like this right under the seat:
    http://shorterlink.org/3137
    If you have the original thermal flasher you'll also need these to get it to work right:
    http://shorterlink.org/3138
  12. worm
    worm Member
    Attleboro, Massachusetts
    Hey Nimitz,
    Do you know what the specs on those resistors are??
  13. nimitz
    nimitz Member
    McHenry, IL, US
    Not off the top of my head but I'll go check the ones I bought for just such a purpose and get back to you today.
  14. Gamuru
    Gamuru Guest
    Granite Falls, WA
    worm, an 1156 light bulb is rated for about 21 watts at 12 volts. Watt's law tells us that the amperage should be 1.75 (I = P/V or I=21/12). Then Ohm's law says the resistance should be about 6.85 ohms (R = V/I or R=12/1.75). Hope that helps.
    EDIT: I should add that you need to look at the turn signal circuit as a whole (Front and Rear on one side or the other). If you're replacing both bulbs (front and rear) with LEDs, then you need to calculate your total resistance as if you're solving for a parallel resistance circuit. See here for more information. Put simply, your needed resistance value would actually be closer to 3.425 for this particular circuit (refer to Fig. 3-44). If you're replacing just the rear bulbs, then refer to Fig. 3-45. You'll have to plug in your own numbers though.
  15. worm
    worm Member
    Thanks nimitz.
  16. nimitz
    nimitz Member
    McHenry, IL, US
    The resistors I'm using for my turn signals are 4.5 ohm 50W aluminum houseing ones from Mouser Electronics:
    http://shorterlink.org/1583
    A bit excessive but the don't get near as hot under use.
