Xj 650 maxim not sparking
Discussion in 'XJ Technical Chat' started by matthew fitzpatrick, Jul 31, 2016.
  1. matthew fitzpatrick
    matthew fitzpatrick Member
    wirral
    My 1983 xj 650 5g2 maxim isnt sparking it will only turn over when the side stand switch is connected so tried new coils tci unit ive ohms & continuity checked all bits i need to voktage testef everything coils have 12v etc etc so popped the side cover off to find the pick up is getting hit by the roter i have tried to adjust it but it's in a set position any ideas also wires didnt look healthy but again checked and there pulling readings my concern is the roter arm hitting the lower pick up yet clears the top pick up fine
  2. k-moe
    Give us a photo or video of the ignition pickup. Turn it with a wrench if you do a video.
  3. Jetfixer
    How old is your battery, is it serviced to proper level with distilled water? Low battery voltage can also cause ignition problems.
  4. matthew fitzpatrick
    wirral
    Battery is 4 weeks
    battery is fine problem lies with either tci unit the pick ups or the rotar hitting the pickup
  5. k-moe
    The reason I ask for a video is that I suspect a serious amount of wrongness, and am hoping to have that disproven with evidence.
    Is the crank cover on that side damaged in any way?
    matthew fitzpatrick likes this.
  6. matthew fitzpatrick
    wirral
    k-moe nothing on this xj seems right , what is your guess an ill try an get pics asap
  7. matthew fitzpatrick
    wirral
    and no damaged casing
