Picked up a 1981 Seca 750 the other day
Discussion in 'Hangout Lounge' started by billrocks45, Sep 30, 2016.
  1. billrocks45
    billrocks45 New Member
    [​IMG] Picked up this Seca last week. Seems to run well. The oil and batt lights stay on on the Atari. It looks like the sensors are missing. I think I'll leave the Atari on and try to put some new sensors in. It has a claimed 8200 miles.
  2. k-moe
    The battery sensor wire is white with a red trace, near the battery. It measures the electrolyte level in one cell if you have a traditional flooded battery, and new sensors are available. If you want to, it can be modified to be a battery voltage sensor by using a 2.2 K ohm resistor in place of the battery sensor. Using a bullet connector and a ring connector, hook the resistor up to the sensor wire and the positive battery terminal (cover it all in shrink-wrap).
    The oil light is likely on because either the oil level is low, or the oil level float is stuck. Change the oil and add a dose of Seafoam (follow the directons on the bottle). Run it like that for a few hundered miles to clean any sludge out.
  3. billrocks45
    Thanks, K-moe. I'll see what I can do. For some reason, my picture isn't posting. I'll work on that as well.[​IMG] [​IMG] [​IMG]
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    If you want the lazy fix for those lights, you can cover them with electric tape. Outta sight!
  5. k-moe
    Seized engine .....
    Charging system failure, better head home without shutting the engine off....
    Lazy fixes make a fella have to work hard.
  6. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Welcome aboard.
    Gary H.
