Engine install
Discussion in 'XJ Technical Chat' started by shovel268, Oct 11, 2015.
  1. shovel268
    shovel268 Member
    Edmonton Alberta Canada
    Dose anyone k ow where I would find in the hanyes hiw install the motor took it out to have some welding done times gone by and now I forget how to reverse what I did to get it out
  2. Big swede
    Big swede Active Member
    Gothenburg,Sweden
    Got my engine back in yesterday, just ask and i'll try to help.
  3. shovel268
    shovel268 Member
    Cool thanks I'll take some pictures to make sense of my problem
  4. k-moe
  5. shovel268
    shovel268 Member
  6. shovel268
    shovel268 Member
  7. k-moe
    The sleeves slot in to the motor mounts. You'll want to have a jack under the engine so you can get it at the correct height.
  8. shovel268
    shovel268 Member
    OK thanks I'll try tomorrow ran out of cus words for tonight lol
  9. k-moe
    Imagine how many more you'd know if you were taking a rubber mounted engine case and putting it in a frame that was meant for a solid mounted case :)
  10. shovel268
    shovel268 Member
    Bahahaha how many engine mount dampers should I have I only have 4 but I see 2 large openings in the front of the engine I've got 2 dampers in the front lower and 2 in the rear am I missing some been looking in my garage for others but haven't found anything
  11. k-moe
    There are six dampers total. Two at the rear. Two in the lower front and two in the upper front. The lower front pair are shorter than the upper front pair. The rear pair are of a larger diameter than the others.
    shovel268 likes this.
  12. shovel268
    shovel268 Member
    OK so I'll have to find the others
    Thank you
  13. shovel268
    shovel268 Member
    Well I'm finally at it again ,I can't seem to get the rear of the motor into the frame ,it seems too far forward and the differential seems to be keeping it from lining up ,I get,the right side in .but the left side is off kilter and the long bolt jams up wtf?
  14. k-moe
    Pics help.
    Differential? Are you working on a car now? Are you talking about the final drive?
  15. shovel268
    shovel268 Member
    Bahahaha no I will post pics I mean the connection between the motor and the shaft drive
  16. shovel268
    shovel268 Member
    Hey I'm trying again to get my motor in and can't seem to get it to lineup with the motor mounts and the dampers keeps falling out
  17. XJ550H
    here is how to remove it so if you start at the end and go backwards
    install from right side slide motor to rear support with jack
    and install rear engine mounting bolt
    http://www.xjcd.org/650_engine_removal
  18. k-moe
    Are you using a jack to support the engine while you line it up?
  19. shovel268
    shovel268 Member
    Yes I'm using a jack but the motor is never level enough to get all sides to lineup I get in lower fronts in but then the top or rear are way off and vise versa I
    thanks for your help it's getting the engine to slide backwards into the rear mounts the engine is so heavy it doesn't budge too easy
  20. k-moe
    All of the rubber dampers need to be in their bores before placing the engine into the frame (although you can get the fronts in with a little repositioning if the engine is already in the frame).
    If the rubber dampers are loose in their bores you can get brand new replacements from Chacal (they do cost a bit, but may be worth it), or use a dab of black RTV to hold them in place while you line the engine up in the frame.
    The rear mounts need to be aligned in the frame first. Put the nut on the bolt. but do not tighten it yet.
    Once the rear of the motor is supported you can line up, and work on, the front mounts. The frame ears on the upper front mounts should be done last. Leave all fasteners fairly loose until everything is in place.
  21. shovel268
    shovel268 Member
    OK sounds good I'll give it a try
