headlight relay electrical short in 82 XJ550
Discussion in 'XJ Technical Chat' started by jtalafous, Aug 21, 2007.
  1. jtalafous
    jtalafous Member
    Austin, TX
    After reading all the relevant posts here and getting the electrical diagrams, I found that elusive electrical short in my headlight relay. Its case was beat up and bent and the short was coming from there. The replacement relay is either $84 from Yamaha. So I'm trying a SPST relay for $0.88:
    339-098 Omron Relay 12 VDC 15A $0.88
    http://www.partsexpress.com
    Hope this helps the next guy.
  2. PghXJ
    PghXJ Member
    Pittsburgh PA
    post back with results and how you connected it up. That will help people more in the future.
  3. jtalafous
    jtalafous Member
    Austin, TX
    here are the results. I think it worked, but since I inherited the bike with the short, and the headlights never worked in the first place, I'm not sure what it is supposed to do.
    With my new relay, the headlights come on, but they don't turn off during cranking of the engine. This is incorrect observed behaviour, right? But are they supposed to do either:
    A. Turn on except when cranking (thus can be used to light up the road side in an emergency without the engine running)
    B. Never come on except when the engine gets up to speed?
    So I ordered a new standard relay, and the behaviour is the same. So it appears that the relays work, but that the circuit powering its coil is always ON. Any ideas what could cause this? What is the theory behind the primary side? Is it actuated by the starter button? Or is it sensing voltages with solid state gadgets? What am I up against here?
  4. chacal
    The headlight will SOMETIMES come on during cranking, as the relay has a certain "trigger" voltage level that latches the relay open, and thus the headlight turns on. Cranking the engine with the starter motor will SOMETIMES allow that trigger voltage to be reached, and the headlight will come on and then remain on until the key is turned off (which de-energizes that circuit and allows the relay to close). When you FIRST turn the key to the ON or RUN position, BUT DO NOT CRANK THE BIKE, the headlight should be off. It may or may not come on during cranking, but always will as soon as the engine fires. The headlight will not turn off UNTIL THE KEY IS TURNED OFF......this means that if the engine dies/stalls/etc. with the key on, the headlight will remain on unless you turn the key off!
  5. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I concur. My experience with the headlight control circuit is exactly how chacal explained. The OE headlight relay has a diode in it that back-feeds power to the latching circuit to keep it alive once energized.
  6. amitlu2000
    amitlu2000 Member
    Durham, NC
    Question about setting up that relay. The one I have now is set up differently than the one pictured when I search for that relay on Parts Express. Mine has its prongs parallel to each other, and the pronged section slides into a matching receptacle. How do I convert to that layout?
  7. chacal
    Hey Amitlu.....I have some good used original relays available, that's the easy way to solve the problem! Let me know if you're interested.
  8. amitlu2000
    amitlu2000 Member
    Durham, NC
    Oh, big time. Is it the headlight relay for sure? If so, I'm waaaay interested.
  9. chacal
    amitlu.....check your inbox, you've got mail!
  10. amitlu2000
    amitlu2000 Member
    Durham, NC
    Posed this question to chacal over PM, but I thought I'd ask for help here, too:
    I went to double check that bad relay this evening, and lo and behold, I think I may have the wrong relay. The colors going to this one are: Red with white tracer, red with white tracer, black with yellow tracer, and sky blue. I checked my CD, and it's only referred to as "relay" on the wiring diagram. It's located on my bike under the gas tank, right where the headlight relay should be.
    Any thoughts?
  11. chacal
    That's the side-stand position relay..............
    Got those, too!
  12. amitlu2000
    amitlu2000 Member
    Durham, NC
    Haha, you're a man of many relays. I had a sneaking suspicion that may be what it was.
    Next question, then. When I swap that out with one of the relays on the opposite side of the battery and turn the key, the headlight comes on but the bike won't start. But when I swap them back, the bike starts and the headlight stays off. Any reason a finicky side-stand relay would cause that?
  13. chacal
    Yes, the bike is wired so that it will not start/run with the side-stand in the DOWN (on the ground) position if the bike is in gear and the clutch lever is not pulled in.
    The entire "safety" mechanism on these XJ bikes is very thorough, and thus very complicated. There are switches, wiring, relays, and a diode block (and some relays also have an internal diode) that all work together to allow certain actions and dis-allow other actions. As such, there are many possible trouble spots.
    One (or both) of those relays may be bad. Unfortunately I don't know enough about the internal circuitry of each relay to be able to fully answer your question. However, when you turn the key on (without starting or even cranking the bike), the headlight should be OFF. Only when cranking (sometimes) and running (all the time) should the headlight operate. It will continue to operate once it has been lit even if the engine dies. The headlight should not go off untilt he key is turned off.
    The side stand relay should not allow the bike to crank (or maybe only to not fire????) when the side-stand is down, and it will kill the bike if put down while the engine is running IF THE BIKE IS IN ANY GEAR (it will allow starting/running if in neutral). I think. Others may correct me on this.
    The service manual specs for both the side stand and the headlight relay specify 100 ohms resistance, and it is beyond the scope of mere words to describe the testing procedures for this. You'll need a factory service manual or the Haynes manual for your model (P.S. yes, you guessed right, I sell those too!); both have great schematics and testing procedures and diagrams.
    BTW, here's some info that I consider reliable (and invaluable), but use at your own risk:
    There are at least 4 relays used on various XJs that look identical: two
    different versions of the headlight relay, the ignition cut-off relay and
    the sidestand relay. While the connectors will allow you to mix and match,
    the relays are different internally. For example, a headlight relay has the
    identical pin-outs as a sidestand relay, but the coil is a much higher
    resistance. The headlight relay resistance is around 90 or 100 ohms while
    the sidestand relay is less than 1 ohm. If you were to install a sidestand
    relay in the headlight relay circuit, it would likely work for a short while
    and then burn out the coil.
    Also, there is no diode in the relay to latch it closed so the headlight
    would turn off when the engine quit running even with the key on. The
    contacts may be rated for different currents. The ignition cut-off relay is
    wired completely different inside and mixing the other two will result in
    either the circuit not working or destruction of the relay or both.
    So, how to tell them apart? The logical thought is to look at the number
    stamped on the relay. Unfortunately Yamaha outsourced the relays and
    used different manufacturers at different times.
    For their own ease of identification, they seem to have used a color
    code system. On the connector side of the relay, look for a dot of paint:
    Yellow: Headlight relay for most XJs that have them
    Red: Headlight relay for XJ900*
    Blue: Sidestand relay
    none: Ignition cut-off relay.
    NOTE THAT THIS "DOT OF PAINT" MAY HAVE RUBBED OFF OVER THE YEARS.......
    Now, the locations vary by model, but on a 750 Seca the headlight relay
    (Yellow) is behind the left side cover, the ignition cut-off relay (none) is
    below the tank at the rear and the sidestand relay (Blue) is below the tank
    on the left side of the frame just rearward of the coils.
    *The "Red" XJ900 relay will work in place of the "Yellow" relay but the
    headlight will not latch on when the engine dies.
    AND
    If the dot of paint is not found, then it's an ignition cut-off relay. (None
    = no paint dot ;-)
    The resistance specified is for the coil. The contacts should have either no
    resistance (when "closed", ie power applied to the coil) or infinite
    resistance (when open, ie loose in your hand). In the case of a yellow
    headlight relay, there will also be low resistance in one direction between
    the coil and one of the contacts but infinite resistance in the opposite
    direction of those two contacts. This is due to the aforementioned internal
    diode that latches the relay closed once the engine starts. Same with the
    ignition cut-off relay: the coil is internally connected to one of the
    contacts and grounded through a diode.
    Now, as to which contact is which: they are not marked on the relays
    themselves. Best to consult the XJCD wiring diagram or the relay test
    procedures in the factory manual to verify for yourself with a picture. So,
    for example, the headlight relay coil will be the two terminals that connect
    to the white and black wires, respectively. The contacts are the ones
    connected to the Red/yellow wire and the Blue/black wire. The diode conducts
    when forward biased from the blue/black to the white (ie +12v applied to
    blue/black).
    With the ignition cut-off relay, the two red/white wires are the contacts.
    The coil is connected internally between one of those and the blue/yellow
    wire. There's also a diode, forward biased from the blue/yellow to the light
    blue.
    The sidestand relay is the most straight forward in that it has no internal
    diode and all the wire colours are different. The coil is between the
    red/white and blue/yellow wires. The contacts are between the red/white and
    black wires.
  14. MiCarl
    The headlight relay works like most relays - the secondary (wires for the headlamp) is closed when the primary (alternator input) is energized. It has an added diode to latch it on so the light stays on even if alternator output stops (bike stalls).
    The sidestand relay works a bit backwards. The secondary (wires to short out the TCI trigger) is closed when the primary (sidestand switch, clutch etc) is not energized. So, if you put it in place of the headlight relay the headlight will be on until the bike starts.
    If you put the headlight relay in the socket for the sidestand relay it will only let the bike run in an UNSAFE condition (bike in gear, sidestand down, clutch not pulled). The bike won't start if the clutch is pulled, or the bike is in neutral.
    So, bottom line is - swapping them is unsafe. And if you do get it started without having an accident the headlight will go out.
    Interestingly though, since when you swap them the headlight comes on but the bike won't start you've probably proven that both relays are functioning properly.
  15. MiCarl
    I've looked at the relay you purchased for the headlight. It appears to be a NC relay - IE works like the sidestand relay. If so, the headlight will be on until you get the bike running at which point it will turn off (assuming the alternator supplies the right trigger voltage).
    Remove the relay from the motorcycle. Check continuity between posts 1 and 4 - if there is continuity then this relay definitely won't work for your purposes.
  16. amitlu2000
    amitlu2000 Member
    Durham, NC
    Well hmm, I'm way confused now. As far as the sidestand relay goes, I can't start the bike with it down, so maybe the relay I tried swapping is actually the one that needs replacing?
    I assumed it was the sidestand relay that was bad because the headlight wouldn't come on when it was in its original position, and the bike wouldn't start in its new one. But maybe it's like MiCarl said and the sidestand relay is doing its job and I'm either looking in the wrong place or looking at the wrong part to replace.
    Chacal, I'll write down the paint dots and track down which relay I was swapping with. I think that may go a long way in figuring out what's up.
    Yay electronics!
    Thanks for all your help, guys. I'm just sure I'll get to the bottom of this.
  17. chacal
    Welcome to the club!
    If the sidestand relay is operating properly, you should NOT be able to start the bike with the sidestand on the ground ("down") UNLESS THE BIKE IS IN NEUTRAL. If the tranny is in neutral, then you can start the bike, but as soon as you attempt to put the bike in gear (with the side stand down) the ignition will quit.
    If the sidestand is down, and the bike is in gear, then you can only start it with the clutch lever pulled in.
    The above statement is predicated upon the clutch safety switch operating correctly.
    I think all of the above is correct.......
  18. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Hey, chacal, you changed your avatar.
  19. chacal
    I know....now I'm hauling butt, really red-lining!
    And it indicates just how fast I'll ship out orders of XJ parts to people!
    BTW, if it makes any difference, I was actually inspired to even put up an avatar (the one before was the website's "default" avatar) by your own head-bangin', rockin' and a-rollin', gear-bangin' avatar.
    At least, I think that's a guitar you're holding onto......
  20. amitlu2000
    amitlu2000 Member
    Durham, NC
    All good there. Maybe I just need to track down the headlight relay for real and take a look at/replace it?
  21. MiCarl
    Yamaha service manual shows the headlight relay under the rear of the fuel tank (It is sometimes wrong!)
    Check to make sure you have the correct relay- the wires to it should be white, black, red w/yellow stripe, blue w/black stripe.
  22. Gamuru
    Gamuru Guest
    Granite Falls, WA
    To test the wires to make sure they're okay, the Red/Yellow wire should have battery voltage on it when the ignition switch is turned on. The White wire should have voltage (varies with engine speed while cranking) when you're cranking the engine or after the bike starts. If you jumper battery voltage to the Blue/Black wire, the headlight should come on. The Black wire should have continuity to ground. Test that with an Ohm Meter or hook a test light between the Black wire and the Red/Yellow wire and then turn the ignition switch on. The test light should come on. If all of that checks out, the relay is probably bad.
  23. MiCarl
    Just went and looked. Headlight relay is under LH side cover just above the chain box.
  24. amitlu2000
    amitlu2000 Member
    Durham, NC
    A hah! I'm 99% sure that's the relay I swapped the sidestand relay with. That would explain things a bit. I'll check the wiring later tonight and get back to you all. Thanks a bunch - I think we're close to solving this riddle!
  25. amitlu2000
    amitlu2000 Member
    Durham, NC
    OK, latest update here. I tried replacing the relay down where the actual headlight relay is, with no luck. Then, on a hunch, I decided I try swapping fuses, just in case there was something off there. I swapped the main fuse with the headlight fuse, and the bike started up fine. But now, even if I have the key out of the bike, the neutral indicator light remains on when it's in neutral, and it'll start without the key in. Oh, and the headlight won't come on :p.
    I take it there's an ignition relay problem? And is it time to upgrade the problem from "headlight relay" to "electrical"?
  26. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I'm wondering if you've got the safety relay swapped with another.
  27. amitlu2000
    amitlu2000 Member
    Durham, NC
    I don't think so. I didn't touch it when I was swapping stuff out last, unless it's been a problem all along, but everything worked fine until I dropped the bike a couple months back.
  28. Gamuru
    Gamuru Guest
    Granite Falls, WA
    If you apply the brake, does the brake light come on with the key out of the bike?
  29. Kevin59
    Kevin59 New Member
    What is the normal voltage level on the "signal" circuit to the headlight relay on a Seca 650 once the engine is up and running? I see from the wiring diagram that the signal starts out as AC straight off the alternator.......is it converted to DC before going to the headlight relay?
    Thanks,
    Kevin
  30. jtalafous
    jtalafous Member
    Austin, TX
    I installed a new headlight relay but I am having problems still. The headlight is off before starting, but it never comes on after the engine is running. Now I am not sure whether the relay is the problem or not.
    Are there "specs" I can test with a volt meter? There are 4 wires: Black, White, Red with Yellow stripe, Blue with Black stripe. What kind of voltage should show up across which two wires when the engine is running. If I touch which two wire to turn on the headlight at all times and bypass the relay (to test that lamp is not burned out). Reading schematics is not my forte.
    Thanks,
    JT
    XJ550 1982
  31. wamaxim
    wamaxim Active Member
    Vancouver, USA
    You can check the headlight using an ohmeter. There should be three terminals coming off the heradlight. Put your meter on ohms and touch the leads together. You should read 0 ohms(short). No put one lead on the center pole on the light and the other lead on one of the other 2 poles. Your meter will either read infinity( the filament is bad) or a near short(the filament is good).
    Check again from the centert pole to the other connector.
    Before you do this just flip the high beam switch and fire it up. There arer 2 filaments inside the lamp. Chances are only one would be bad. But not always
  32. jtalafous
    jtalafous Member
    Austin, TX
    Thanks wamaxim,
    I followed your advice, and the headlight is fine. It took off the connector to the headlight relay, and jumped the striped wires, and the headlight came on. Therefore, I tested the voltage across the black and white wires, which must energize the relay. Before my 82 XJ550 was started, the voltage was zero. After my bike was started and running (yeah baby!) the voltage was still zero. This does not prove the relay is good, but I would bet the farm on it that it is since Chacal tested it. Therefore the circuitry on the black and white wires is failing.
    What decides and then supplies voltage to the black and white wires after starting? How would I debug it?
    JT
  33. jtalafous
    jtalafous Member
    Austin, TX
    In the Yamaha manual, in Chapter 6, there is a much clearer schematic. The headlight relay has a diode in the relay itself (btw: sidestand relay does not). Which loops back and latches on the current, as everyone has been describing.
    Since I am not getting current on the white wire, and according to the circuit diagram, the white wire is a straight shot into generator with one diode along the way, and this diode is located in the headlight bucket in the diode block. White wire IN and white wire OUT from the diode block should show current. Diode should also show different resistance each way, maybe the manual provides those numbers?
    Off to find out. Hope this helps the next guy.
  34. jtalafous
    jtalafous Member
    Austin, TX
    I think my diode is shot. Can anyone get a reading?
    1. Open the headlight bucket.
    2. Disconnect the diode block, look at connector terminals, with casing notch up.
    3. Measure ohms from the center terminal to the lower right terminal. According to my calculations, these are the White wire and White/Green stripe wires, and they connect to the two white wires on the mating connector which go to the headlight relay white wire.
    4. Reverse polarity.
    I am getting infinite resistance both ways. I tried all possibilities from center term to any other, both polarities, and Nothing.
    I can get a zero ohm reading on other terminals.
    Is my diode shot? Or is this a normal reading?
  35. jtalafous
    jtalafous Member
    Austin, TX
    The Clymer manual for the XJ550 models says to test the diode block in
    this manner (strangely, it makes no mention of the diode
    in the 1981-83 section, but only in the 1984-later models
    addendum):
    a) Set ohms scale to r x 1
    b) Test as follows:
    Red (+) lead from tester on: Green wire
    Black (-) lead from tester on: Blue wire with white stripe
    Result should be: 0 ohms
    Red (+) lead from tester on: Blue wire with white stripe
    Black (-) lead from tester on: Green wire
    Result should be: infinity
    Red (+) lead from tester on: White wire with green stripe
    Black (-) lead from tester on: Solid white wire
    Red (+) lead from tester on: Solid white wire
    Black (-) lead from tester on: White wire with green stripe
    Red (+) lead from tester on: Yellow wire
    Black (-) lead from tester on: Light blue wire
    Red (+) lead from tester on: Light blue wire
    Black (-) lead from tester on: Yellow wire
    Black (-) lead from tester on: Black wire with red stripe
    Result should be: 8.2 ohms
  36. jtalafous
    jtalafous Member
    Austin, TX
    It was the diode block! The headlight relay system now works perfectly. When you nail the problem, that makes it all worth it.
  37. TheHound
    TheHound Active Member
    Scotia, NY
    Nice job, it feels good.
  38. chacal
    Who loves ya', baby? :D
  39. jtalafous
    jtalafous Member
    Austin, TX
    Chacal, you are da man!
