xj550 rear turn signals
Discussion in 'XJ Modifications' started by ink251, Sep 28, 2007.
  1. ink251
    ink251 Member
    Auburn, AL
    I would like to replace my rear turn signals without spending too much money. What have you guys done as far as aftermarket turn signals? I would rather not add an IC or mess with the flashing circuit. Looking for some signals that don't poke out as much but are equally visible.
  2. Deathmetaldan
    Deathmetaldan Member
    Sunbury PA 17801
    trim the stalks, its basically free if you do it yourself
  3. Anthony14
    Anthony14 Member
    Mississauga, Ontario
    Try ebay, you may be able to pick up a set of nice looking ones for a good price.
  4. ink251
    ink251 Member
    Auburn, AL
    I ended up just taking off the stock turn signals, removing the bulb enclosure from the rubber stalk and rigging together some plumbing fixtures so the bulb enclosures are directly attached to the bike.
  5. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I just got some turn signals from a FJ. They bolt and wire up without any modifications .I have short ones on the front long ones on the back. After market where $16.00 each.
