Bent forks on 86XJ700.What other models have the same forks?
Discussion in 'XJ Technical Chat' started by Mercuralis, Oct 10, 2007.
  1. Mercuralis
    Mercuralis New Member
    SLC, UT
    I was letting a friend of mine get some riding time in on my bike before he got his up and going and he lost control and hit a wall at about 35mph. Luckily he's alright, but my front forks are bent, and wedged the tire between the headers. The rest of the bike seems to be okay (though, I'll be looking over it more extensively later).
    I'd like to retain the same fork length and front end pressure of the stock 86 XJ700 forks. What other bikes used the same forks? Or does any one know where I can get another set for fairly cheap?
    Thanks.
    **EDIT**
    I tried to do a search, but all I found was XJ550 people trying to swap up to 750 or 1100 forks.
  2. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    Have you tried Ebay?
    forks from the maxim-X should match.
    I researched at one time for matching part#´s between the Virago and the Maxim (as the fork seals fits both models= same inner tube diameter) because I have some pitting on the inner tubes.
    The part#´s don´t match but if I stumble across a set of forks from a Virago I´ll give it a try.. not so sure about the outer tubes though (if holes for calibers and front fender will match - depends a.o. on the front wheel size..).
  3. MaximumX
    MaximumX Member
    Ottawa, Canada
  4. Nick
    Nick Member
    Vernon, BC Canada
    As per information on the XJCD…..
    The Right Hand Front fork assembly (part # 1FG-23103-00-00)
    and
    The Left Hand Front fork assembly (part # 1FG-23102-00-00)
    fit the following models:
    1985 XJ700N
    1985 XJ700NC
    1986 XJ700S
    1986 XJ700SC
  5. capy
    capy Member
    Florida
    Re: Bent forks on 86XJ700.What other models have the same fo
    I have a set of triples from a 85 700 and an extra set of forks. The triples are ready to ship but the forks I won't have available for a few more weeks. If you need the triples, let me know.
  6. Robert
    Mercuralis, I'd back up the replacement of the forks with new steering head bearings. Cheap insurance that you don't have shot bearing races as a result of the impact.
  7. Mercuralis
    SLC, UT
    That's an excellent suggestion Robert. Thanks. This will be the first fork swap I've done, and I wouldn't have even thought of that.
    I'll look into the Virago set and see if those will work. I think I'd rather find a set of actual XJ700 forks though. Nicks info seems to imply the XJ700s were fairly unique.
    capy, the Triples are essentially the steering knuckle, right? That holds the folks in place? I don't think mine is damaged. I'll pass on that for the moment. I would be interested in the forks if you still wanted to get rid of those in a few weeks. I'm not in a rush.
    Thanks for everyones input.
  8. Mercuralis
    SLC, UT
    Does anyone have access to both an XJ700 and a twin disc Virago? I'd like to get some measurement on the forks between the two. Are the tube diameters the same? Is the travel the same? Is the sitting length the same?
