Springtime Rituals
Discussion in 'XJ Technical Chat' started by dkavanagh, Apr 4, 2017.
  1. dkavanagh
    Rochester, NY
    For those of us that have cold winters, what do you normally do in the spring to get the bike ready?
    I rode my bike anytime the temperature got above 50, so it hasn't been sitting, but...
    Thinking tire pressures, re-sync and check mixture, oil change?
    When does the non-winter-mix fuel return to the stations?
  2. k-moe
    Tire pressure, check battery electrolyte level, check the oil level (basically a full pre-ride check), take the rags out of the exhaust and intake, start the bike, ride it, fill the tank with new gas when the red light comes on.
    My pre-storage prep is what allows the spring to go smoothly.
    cgutz, PilotSmack and Stumplifter like this.
  3. LeClairerog
    LeClairerog 1982 XJ 750 Maxim
    LeClaire, IA
    That's the first time I've heard about using rags. I will give that a shot next winter.
  4. k-moe
    It helps to keep the mice out.
    LeClairerog likes this.
  5. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    I use duct tape and then put a piece on my ignition key hole - to remind me.
    Hoping to leave work today and fire her up.
  6. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    I do basically the same as Kmoe, minus the rags. I intended to add steel wool in the exhaust and intake, but never got around to it.
  7. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    I use old socks... cotton won't scratch my shiny mufflers, and holds them on there really well, and I can shove the excess in the hole to keep critters out. I agree though, pre-storage is huge, and can be used as a massive preventative maintenance program... you discover problems in the late fall, and have 4-5 months to save for and purchase parts. Springtime, take a day and reassemble. I usually ride enough that I need to check my valves and such in the spring anyway, so it ends up being a basic overhaul.
  8. Craig B
    Craig B Active Member
    Ontario, Canada
    Install battery. Fire it up.
    Sit back and watch it F'n Pour Rain for days on end.
    Tim O likes this.
