Alternate triple tree for XJ550 Maxim?
Discussion in 'XJ Modifications' started by Iamwayno, Apr 17, 2017.
  1. Iamwayno
    Iamwayno Member
    MI
    Does anyone know if there's a triple tree from another bike that would fit on an 81 xj550 maxim? Something that would fit the forks I already have and hopefully holds the same size 7/8 handle bar.
    As you guys probably know, the handle bar brackets on the stock triple tree kinda curve in toward the tank, which causes my slightly curves drag bars to hit the tank (the corners of the controls hit the tank). I'm kinda hoping by using a tree that doesn't force the handle bars to sit closer to the tank, that it'll help the problem.
    I'm thinking possible a virago tree or maybe even the seca version of that bike?
    do a site search for fork swaps there are a couple of threads about someone changing front forks with differenr bikes
    Iamwayno likes this.
  3. Iamwayno
    Iamwayno Member
    MI
    Well I'm just trying to swap the triple tree and not the forks too hopefully
  4. XJ550H
    try some risers you can roll this style forawrd
    http://www.ebay.com/itm/Black-Aluminum-7-8-22mm-Motorcycle-HandleBar-Handle-Fat-Bar-Mount-Clamps-Riser/272617163435?_trksid=p2047675.c100005.m1851&_trkparms=aid=2220072&algo=SIC.MBE&ao=2&asc=40130&meid=bdc11d6e3a1a42b0bfd3762fe3aa53a2&pid=100005&rk=1&rkt=6&sd=252719423244
    or this style to give a little more lift
    http://www.ebay.com/itm/Emgo-23-093...m33c161c93a:m:muj_LLxGNsJdEhaHYN6RUkg&vxp=mtr
    Aluminum Handlebar Riser Kit
    • Allows the rider to easily tune height of handlebars
    • Can raise the height of the handlebar in 5mm increments with a maximum height increase of 25mm
    • Available for 7/8" or 11/8" diameter handlebars
    • Raw aluminum or black anodized finish
  5. Iamwayno
    Iamwayno Member
    MI
    Well, see...the problem is the rise. Look up how an 81 Maxim 550 triple tree looks. The bar mounts have a built in rise as well as a significant pull-back. I'm trying to not have that.
